Author Topic: Randomjords....... MK2 G60 ..... Solded  (Read 76213 times)
Offline Organisys
  • Old and Slow...
Re: Randomjords....... Proper MK2 G60 Wheel pic page 9
« Reply #90 on: 31 December 2011, 18:14 »
Wheels look interesting Jordan.
Offline RandomJord
« Reply #91 on: 31 December 2011, 18:38 »
I may be having second thoughts on them, got a bit of an 'out there' plan that I may go with instead.
In which case theyll be on eBay along with the valver!
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
Offline RandomJord
Re: Randomjords....... Proper MK2 G60 - Nearly coming home!
« Reply #92 on: 18 January 2012, 10:37 »
Quick question peeps, does the Gearbox in the G60 crossover with any other cars?
Trying to find a replacement ASAP as mine now has a habit of jumping out of 5th!
Offline lemski
  • 16v
« Reply #93 on: 18 January 2012, 12:08 »
There hydrolic clutch arnt they? Or is that the corrado g60? If so abf box and flywheel would be a fairly easy swap over
Offline RandomJord
« Reply #94 on: 18 January 2012, 12:20 »
MPG Horrific and it is ssoooooollldd
Offline Organisys
  • Old and Slow...
« Reply #95 on: 19 January 2012, 20:14 »
Jordan, get a CTN code box from a MK3 tdi. Apparently the ratios work really well with the G60 including a taller 5th to keep the revs down when cruising to give you better MPG.
You also improve the very short 1st and 2nd.
Lots of people have done this mod. Good news is a CTN box can be found refurbed for a few hundred queens heads.
 :smiley:
Offline RandomJord
« Reply #96 on: 21 January 2012, 21:22 »
ended up with an ASD, lets see how that go's!
didnt you get a CTN?
Offline topher
  • Administrator
  • fully functioning
« Reply #97 on: 21 January 2012, 22:25 »
thanks to a delay caused by a certain forum mewmber's unbleedable brakes/duff master cylinder :grin: the box will go in on monday. The breather hose with the hole in it is an obsolete part, keep an eye on the classifieds!
Offline RandomJord
« Reply #98 on: 22 January 2012, 13:09 »
Balls, can i get one made?
Offline Horney
« Reply #99 on: 22 January 2012, 13:13 »
Not sold it yet?
