Author Topic: funny vibration in front end wired  (Read 2099 times)
Offline GJSEB79
Re: funny vibration in front end wired
« Reply #10 on: 26 November 2011, 21:44 »
tell me dave i went for powerflex as for of big name would be better quality obviously not its wired its like a vibration in the steering wheel i was hoping it might be wheel bearing or something
Offline Dave_IOW
« Reply #11 on: 26 November 2011, 22:02 »
Hmm not sure, everything done back up tight?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline GJSEB79
« Reply #12 on: 26 November 2011, 22:05 »
yeh checked it and double checked it again incase i missed something wired really is  :huh:
Offline Dave_IOW
« Reply #13 on: 26 November 2011, 22:16 »
What you can feel engine vibration through steering wheel?
Offline GJSEB79
« Reply #14 on: 26 November 2011, 22:32 »
yeh aswell as like when you go over pots feel every pin on the road but there is alot of vibration on steering wheel so i though engine mount or wheel bearing
Offline Dave_IOW
« Reply #15 on: 27 November 2011, 10:31 »
Could be either tbh, does your car start humming over like 40mph?
Offline brianpologti
« Reply #16 on: 27 November 2011, 10:51 »
Check the strut bolts , the clamp one at bottom, see if the strut is siding up and down and touching one the cv joint,
Offline GJSEB79
« Reply #17 on: 27 November 2011, 19:12 »
do you mean on the front suspension struts mate ie bolt in engine bay
Offline GunnerCP
« Reply #18 on: 27 November 2011, 22:35 »
No, I assume hes talking about the one at the base of the strut at the back. There's a bracket that holds the strut in place relevant to the hub....
