Author Topic: Vr6 supercharged??  (Read 5968 times)
Offline Ess_Three
Re: Vr6 supercharged??
« Reply #20 on: 25 November 2011, 17:02 »
I read that the standard vr engine is good for 300bhp, any truth in this?
Good for 300 BHP how?
N/A you'd be very lucky to get 300 BHP - even with wild cams, big valves and seriuous headwork, I think 300 BHP is out of reach...and if you could, it would be so non-standard that you could hardly call it 'standard.
Forced induction?
I guess so...with a decent IC, bigger injectors, a small pully on a VF S/charger...then I suppose 300 BHP is achievable on standard internals.
..but gaining motorcycles.
Offline Ess_Three
« Reply #21 on: 25 November 2011, 17:06 »
also the obd1 bottom end is stronger than the obd2  :wink:
Why?
I think he was joking...
The engine is the same. OBD doesn't even exist in the UK - it's an American thing...the stepper motor TB of the later cars and switch from coil pack to dizzy was about the only change...the hardware of the engines are the same.
Offline tweed
« Reply #22 on: 25 November 2011, 19:02 »
Why?
yep It's only because I have one.
 but the aba obd1 is ment to be better than the aba obd2. I read this on vwvortex http://forums.vwvortex.com/showthread.php?4966752-TECH-Differences-between-OBDI-amp-OBDII-heads-and-blocks
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #23 on: 25 November 2011, 20:07 »
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline leigh_harty
  • Audi AGU
« Reply #24 on: 25 November 2011, 20:35 »
My mates old VrT was running 412bhp on full boost and around 330 turned down (figures not accuate)... for around 5 years without fault. Eventually the engine went because he ignored a faulty waterpump and a piston let go. Dropped a sharan vr6 in there and ran about 380 for a good while until sold
Many insane and loads of unusable and wasted power
Dont lose your dinosaur!
Offline Ess_Three
« Reply #25 on: 25 November 2011, 20:50 »
US engines are different...their gearboxes too.
Aren't UK 2.8 VR6s AAA engine codes?
And 2.9s ABV?
That article is referring ro the ABA - that's a 4 cylinder!  :tongue:
« Last Edit: 25 November 2011, 20:52 by Ess_Three »
« Reply #26 on: 25 November 2011, 21:42 »
And 2.9s ABV?
Yes 2.8 is AAA and 2.9 ABV :afro:
Offline Ess_Three
« Reply #27 on: 25 November 2011, 21:50 »
And 2.9s ABV?
Cheers Wayne. Thought they were  :smiley:
