Author Topic: When changing a sensor....  (Read 2272 times)
Offline stow1985
  • 'when im cleaning winders'
« on: 20 November 2011, 10:49 »
Hi all,
As some of you know my car (MK3 GTI 8V) hasn't been running to healthy recently, but after a bit of head scratching, autodata reading and some multimeter probing  :rolleyes: I've managed to find the fault...temp sender or (ECT) Engione coolant sensor as is says in the auto data book...
Autodata: 80*C - 325ohms
Mine:       80*C - 149ohms :sad:
I wanted to know once I've changed sensor do you need to reset the ECU? disconnect the battery? remove Fuse? or is it a simple swap over and let it sort its self out???
Offline harlemex
Re: When changing a sensor....
« Reply #1 on: 20 November 2011, 14:15 »
just swap em over all will be good.
Offline stow1985
« Reply #2 on: 20 November 2011, 21:06 »
Nice one thanks  :cool:
