Author Topic: 1.8T NA camshaft?  (Read 6300 times)
Offline Chris.
1.8T NA camshaft?
« on: 19 November 2011, 19:53 »
Does it really make any difference?
Would it make any difference on my setup Nick?
I have the chance to pick one up for about £50 and fitting would be nout so no loss there.
Worth it?
Chris
Click For Build Thread
Offline Wazzzer
  • Golf GTI 1.8T AGU
Re: 1.8T NA camshaft?
« Reply #1 on: 20 November 2011, 14:51 »
I hear they can release a bit more power...
Offline Chris.
« Reply #2 on: 20 November 2011, 14:51 »
How much though lol
jamie16v
« Reply #3 on: 20 November 2011, 15:18 »
inlet or exhaust?..  :tongue:
Offline Chris.
« Reply #4 on: 20 November 2011, 15:46 »
Inlet
Offline danny_p
« Reply #5 on: 20 November 2011, 16:06 »
it worth fitting them if there hanging about ?  have a dead 20v na i chould rob the cams out and try them in the passat if its worth doing
« Last Edit: 20 November 2011, 21:11 by danny_p »
all the VW's have gone bar 1.
Offline Chris.
« Reply #6 on: 20 November 2011, 16:07 »
its something id Like to do on the rollers though.  To see what difference it actually makes back to back.  That way, we have reliable results.
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #7 on: 20 November 2011, 18:45 »
Higher lift/longer duration?
Offline danny_p
« Reply #8 on: 20 November 2011, 21:15 »
what is soposed gain ?
chould test it back to back on dyno without much bother but if it's naff all gain summoning the botherd
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #9 on: 20 November 2011, 21:43 »
  • 20vt inlet 7.67mm lift
  • 20vt exhaust 9.3mm lift
  • 20v inlet 8.3mm lift
  • 20v exhaust 10.4mm lift
From Vortex
If You plan to use big turbo and low boost, use both cams, if You plan to use smaller turbo and high boost, use only ex cam. If You plan to use tiny turbo and ridiculous boost, use only intake cam.
:afro:
« Last Edit: 20 November 2011, 21:48 by Wazzzer »
