Author Topic: bluetooth instalation help  (Read 7971 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: bluetooth instalation help
« Reply #10 on: 19 November 2011, 23:22 »
Sure is - they are pretty straight forward to fit  :wink:
I put the arials behind the A pillar
Mic goes in the overhead console - there is a space for it
not had a Bluetooth module rattle yet - i remove the air con controls and fit the in the space below the nav unit - but I do tape em up well and use double sided foam tape to hold them in place  :wink:
Offline bcarlin
« Reply #11 on: 19 November 2011, 23:24 »
ok the hardest bit might be taking the side pillar trim off but it will be a busy day tommorrow then
does it need switched on with a vag.com cable ?
Offline The Doc
« Reply #12 on: 19 November 2011, 23:28 »
Dead easy, just remove the airbag plug at the top and there is a torx screw inside remove this then pull on the trim and it will come off.
Yes you need vag com - you got it?
Where are you?
Offline bcarlin
« Reply #13 on: 19 November 2011, 23:32 »
not got it  :sad:
im in lanarkshire just outside glasgow,a local vw specialist says he has vag.com but has never activated it before
Offline The Doc
« Reply #14 on: 19 November 2011, 23:33 »
Oh great - fancy a trip?
Offline TJD
  • The quality remains after the cost is forgotten.
« Reply #15 on: 19 November 2011, 23:45 »
Hi,
Doc,
how are you getting the mic to the overhead console (post pillar) and how are you finding the mic reception when its there?
Is mic in pillar an option? (ala p3eps walkthrough?)
Thx for the headsup on my local friendly VCDS man, mortygt140, he's booked in.
Mine hasn't arrived yet either, bummer, fitting it in the dark then one eve :angry:
« Last Edit: 20 November 2011, 00:31 by TJD »
MK6 GT140. Reflex silver. Vancouvers.
Offline bcarlin
« Reply #16 on: 19 November 2011, 23:46 »
3hrs 38 minutes journey -not so good  :sad:
Offline TJD
« Reply #17 on: 19 November 2011, 23:58 »
Don't panic b I'm sure there'll be a friendly VAG/VCDS coder close. :smiley:
Who knew I had one 10 min's away.......well Doc did actually. :grin:
Offline bcarlin
« Reply #18 on: 20 November 2011, 00:02 »
im kind of sh*ting myself about doing this job
think it would be different if it was a old banger and not our new car
Offline TJD
« Reply #19 on: 20 November 2011, 00:19 »
I know what you mean, I am/was the same.
My advice (if you want it) is that it isn't as hard as you ecpect, all the advice/info you need is on this excellent site, do the research, don't rush it, ask, and invest in a set of trim removals tools from flebay. 'bout £8, well worth it!  :smiley:
