Golf mk3
hardmonkeys
Creaky Clutch Pedal
Topic: Creaky Clutch Pedal (Read 1538 times)
Milby
Here all the time
Creaky Clutch Pedal
17 November 2011, 17:02 »
just noticed when i push down on the clutch pedal it creaks. is it jut case of greasing it up a bit ??
MK3 Golf 1.4 SE
sharki786
GOT BOOST??
Re: Creaky Clutch Pedal
17 November 2011, 17:49 »
if its the 8v then you need a new cable or you could take the cable out and then hang it on the washing line or anywhere and throw some oil down it. but best to get a new one from gsf as they have some genuine VW ones
*****MK3 Anniversary*****
*****MK4 GTI T*****
negawsklov
Here all the time
17 November 2011, 18:50 »
Is it easy to do as mrs negawsklov's does the same?
Milby
Here all the time
17 November 2011, 19:26 »
yeh how easy is the job
MK3 Golf 1.4 SE
Seanl
17 November 2011, 19:31 »
Jack up the clutch release mechanism, disconnect at that side, then disconnect at pedal side. Refitting is the opposite of removal.
negawsklov
Here all the time
17 November 2011, 20:32 »
Sounds easy enough, I'll get my friendly mechanic around to do it
harlemex
Reply #6 on:
17 November 2011, 21:04 »
The tough bit is guiding it through the bulkhead.
Golf mk3
hardmonkeys
Creaky Clutch Pedal
