Author Topic: readings from vag-com  (Read 5517 times)
Offline cardconvict
« on: 17 November 2011, 11:27 »
hi all i have a 1.8t golf and decided to get some readings from vag-com to see what boost pressure i'm running at, and a rough bhp
on the boost it hold right up to 5000 rpm then starts to drop off it peaked at 14.9 psi.
And on the bhp it is estimated at 205bhp now can this be right with a ko3 turbo.
The mods i have are forge 007p with yellow spring 3 inch down pipe with decat and 2.5 inch powerflow exquast just seems to me a little high for the ko3 turbo on what i have read already. i'm unshore if it has been remapped in its life but i have never done it to it
Offline daz veedub
  • Operation 1.8t bolf
Re: readings from vag-com
« Reply #1 on: 17 November 2011, 11:34 »
mines a k03 with similar mods 200bhp  :smiley:
and it would of defo been mapped
Offline cardconvict
« Reply #2 on: 17 November 2011, 11:37 »
just when i looked at the readings i thought no that can't be right so took it for a second run and was the same just that read on here that the ko3 will only push up to 180 bhp
Offline daz veedub
« Reply #3 on: 17 November 2011, 11:42 »
 depends on how well the engine running, mods etc etc loads on here av k03 with mods and map running close to or running 200bhp ur readings wont be bang on a doubt so best thing to do is get it rolling roaded for a precise reading  :smiley:
Offline rio_gti
« Reply #4 on: 17 November 2011, 12:50 »
How are you calculating it to get the bhp??
Offline vwblackmk4gti
« Reply #5 on: 17 November 2011, 13:03 »
you need to take into account losses, through your drive train to get an accurate reading.
as above only rolling road session can give you an accurate reading.
or you can use a formulae to calculate power in Kw
Offline cardconvict
« Reply #6 on: 17 November 2011, 16:56 »
i did say in my original post a rough estimate of my bhp lol :tongue: as for working it out i red the highest measurement from vag-com in the air mass meter and devide it by 0.8
Offline Chris.
« Reply #7 on: 17 November 2011, 22:51 »
What was the MAF flow?
Click For Build Thread
Offline cardconvict
« Reply #8 on: 18 November 2011, 12:10 »
164.31 gs at 6500 revs
