Author Topic: low and lumpy idle/stalling when hot  (Read 2576 times)
Offline Gambit
Re: low and lumpy idle/stalling when hot
« Reply #10 on: 18 May 2005, 10:03 »
hall sender has nothing to do with cooling, the hall sender sends a signal to the ecu to tell the coil to fire a spark. when the hall sender goes wonky its sends the signal at the wrong time. causing it to misfire splutter etc
it works on electromagnetic pulse
Offline tinman
« Reply #11 on: 18 May 2005, 11:39 »
for 60 quid i'd change the whole distributor. they do tend to die over time.
Offline rowlers
  • I'm back - MK7 GTI
« Reply #12 on: 18 May 2005, 16:57 »
thanks again fellas.
Hall sender has been fitted today, (i've just collected it from garage - I bottled doing the job myself!!) and it starts better, idels smoother, taking it out later so will let you knw!
Also its going back in on saturday moring for a new clutch cable, the one on it is a fairly new motor factors one, and it keeps slippling so I'm told, a genuine VW will sort it. Also I'm told the temp sender is effed, a motors factors copy makes it worse, so I'm also getting a genuine temp sender fitted on sat!
Cheers will let you know how things get on!
Rowlers
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
« Reply #13 on: 20 May 2005, 12:58 »
would the hall sender cause me cold start problems.  I have had a similar prob with the revs increasing etc.  Thought my clutch was slipping but its intermittent
Offline Gambit
« Reply #14 on: 20 May 2005, 13:10 »
its usually the opposite in that the car is really warm. the rev counter needle will actually bounce about all over the show rather just flucuate.
yours sounds more like a weak spark.
Offline marcogolfo
« Reply #15 on: 20 May 2005, 22:21 »
yeah changed the sprak plugs recently and the car has been crap at starting ever since.  trouble is i canged the fuel filter as well.  dunno what caused the problem tho but the revs do fluctuate. hmmmm
