Author Topic: spinning wheel bolts !?  (Read 7673 times)
Offline mcgee9t2
Re: spinning wheel bolts !?
« Reply #50 on: 14 November 2011, 21:28 »
when i had a wheel bolt stuck in (after some twit tried to nik my wheel and reked the thread on a locking wheel nut), tried everything to get it out, the removal tool which just slipped off until it couldnt grip anymore. numerous chisels and hammers trying to make a slot to get a screwdriver in a windy gun on it, in the end most of the head just snaped off, so we undid 4 bolts a little, not the whole way just enough to put pressure on the stuck bolt but to stop the wheel falling off when the bolt snaped, then took the car into the car park of the garage, and drove around for about ten -15 mins, nothing, then put the car on full lock (so max pressure was on the bolt) and drove around in cirlces for about a min or so untill the bolt snaped and then removed by drilling into it and forcing an allenkey type tool into it and puting in on the windy gun so wheel bolts can put up with quite a bit, mine had 15+ mins of driving by just being held on by one bolt.
also my mate had wheels with a bolt pattern simelar, he ran them for about a year compleatly fine, i however wouldnt like to run them and would prefer something with the multifitment stud pattern more centralised.
Offline Cory
« Reply #51 on: 14 November 2011, 21:35 »
im all for ringing them up and getting my money back, but im pretty sure they will get sh!tty because ive fitted them to the car. . .
will be getting the hub off when i get a 24mm socket, only got the hub bolt and wheel bearing to get off so its gunna take me 20 mins to get off i recon  :cool:
Offline AudiA8Quattro
« Reply #52 on: 15 November 2011, 10:16 »
Trading standards, if its not fit for the purpose..
Offline chezz
« Reply #53 on: 18 November 2011, 19:44 »
Remind me to avoid your technique Sir...I'd rather kiss a Leper!
« Last Edit: 18 November 2011, 19:52 by chezz »
Offline Liftedd
« Reply #54 on: 19 November 2011, 00:10 »
thats crazy!  :shocked:
