Author Topic: matt's mk4 gti 1.8 20v turbo  (Read 4666 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: matt's mk4 gti 1.8 20v turbo
« Reply #10 on: 08 November 2011, 11:51 »
out of interest what did yours map to Wayne?
« Reply #11 on: 08 November 2011, 12:04 »
Not sure yet, hoping to get it on the rollers this month to find, it is an animal on boost, guessing and aiming for 200bhp to 210bhp  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 08 November 2011, 12:10 »
nice, will look out for the results  :afro:
Offline bullzeye
« Reply #13 on: 08 November 2011, 22:40 »
your idle revs dropping will almost certainly be the throttle body needs cleaning, there is a guide on here how to do it or get garage to do it local one charged me £10 and was perfect after,
get your boost pipes checked there prone to hardening and leaking,
take it to somewhere local to you like r-tech or carbon chip tuning for a health check they will check all pipes and dyno it to see what power your getting
one thing with mk4's is if you have a problem your not alone theres always hundreds of others with the exact same problem there quite predictable,
ahh good news if its an easy fix, ill find the thread for a read, ive had a lot of pipes go on other cars, so thinking about the harder/ performance ones you can buy, could save some faffing in the long term, is it just turbo pipes to worry about, or can you get a kit to replace all pipes under the bonnet?
yeah mate as far as im aware its the boost pipes that need checking and im pretty sure you can buy a full stronger pipe set but someone with more knowledge will point you in right direction, very helpful this lot :D
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline m4ttb
« Reply #14 on: 09 November 2011, 07:53 »
What will it cost me for a health check( is that the same as rolling road) and is there anywhere good near Dorset ??
« Reply #15 on: 09 November 2011, 09:25 »
Most companies do that before the remap, not sure on anyone in Dorset.
Offline MattBenney
« Reply #16 on: 29 January 2014, 12:18 »
Hi M4TT B,
               Sorry to be an arse and dig up an old thread, I'm actually after a way to contact M4TTB. Sounds weird I know but I'm after this number plate and when I googled it, there was a link to this thread. I'm hoping he will get an email notifying him of the reply. I am wondering if he fancies selling this number plate to me :smiley:
A bit cheeky I know but I've no idea how else to get hold of him to ask!
I'm not a stalker don't worry, just another VW fan after a plate for my car,
Sorry again for digging up an old thread,
Cheers all,
Matt B (too)
Offline davidgtrr34
« Reply #17 on: 30 January 2014, 18:22 »
120000 miles doesn't sound to bad if the car was looked after but my car is at 141000 miles and the bottom end is gone. I would suggest doing an oil pressure test to check the bottom end bearings and also do a compression test to check rings and valves.
oil pressure  when at operating temp
idle   17psi
2500rpm  50-70psi
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
