Author Topic: Easiest conversion  (Read 10236 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Easiest conversion
« Reply #20 on: 06 November 2011, 22:29 »
to do what Russ (tShirt2k) has done you will be spending a few k more than likely
would be easier to fit 1.8T
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline ortega277
« Reply #21 on: 06 November 2011, 23:06 »
To fit a 1.8t surely will need custom mounts right? Or am I wrong.
« Reply #22 on: 06 November 2011, 23:36 »
I think it will fit all ok with VR mounts.
Offline Dan_GTi8v
« Reply #23 on: 07 November 2011, 10:33 »
1.8t just needs 16v mk3 brackets and vr6 mounts, though a lot of places are now selling vr6 mounts as standard for all models. I got a full set of febi off tierod69 for £50
The 1.8t bolts into the mk4 on the same front bracket as a mk3 as this is attached to the gearbox/starter motor, but also has a side bracket which isnt there on the mk3. All you have to do is unbolt this side bracket and fit the 16v rear bracket into the fixing holes that are already on the 1.8t. Gearbox rear bracket is also the same as the mk3 as you will be running a mk3 02a gearbox
Its pretty straightforward tbh probably no more complicated than fitting a vr6, just more money and a few more bits and pieces need changing over
« Last Edit: 07 November 2011, 10:38 by Dan_GTi8v »
Offline tshirt2k
  • Been there...Done that...
« Reply #24 on: 07 November 2011, 14:43 »
That's what I was thinking get a good mpg with a diesel. He also said the torque would be good as well.
Dan would you be able to link me to tshirt 2k thread please as I can't find it. Thanks
Click the sig below.  :wink: it's not easy. But the base engine can give you options. ~160hp for a scrapyard engine for around £300 ain't to bad and can be fairly economical.
« Last Edit: 07 November 2011, 14:48 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline ortega277
« Reply #25 on: 07 November 2011, 14:45 »
Cool man cheers for the advise guys been really helpful might look into the 1.8t then would be a bit different in a wagon. In terms of insurance what's the deal? Would it be just like insuring a 1.8t or is it more coz in theory it's a custom car.
« Reply #26 on: 07 November 2011, 15:29 »
More as it is a conversion, you will need to find a specialist company.
Offline F17BAD
« Reply #27 on: 07 November 2011, 16:41 »
VR6 mounts not as good as 16v mounts, rear drivers side is uprated on 16v
you are looking at 2.5k plus to do it right and thats if u do the work yourself
if u choose the ABF route, i have a full setup minus gearbox for sale, loom, ecu, engine etc for £250
Offline AudiA8Quattro
« Reply #28 on: 07 November 2011, 16:47 »
Why would the 16v mount be stronger than the vr6 one?
Offline F17BAD
« Reply #29 on: 07 November 2011, 17:04 »
just are, only the rear drivers side, it is heavy duty, same one as used on TDI also.
VR6 uses exactly the same as 8v GTI  all 3 of them, i know because iv checked into all the part numbers that were on my 8v and also on the VR6 high line we broke.. i then checked with the dealer and it was confirmed the rear drivers mount on the ABF is uprated and this is the one to use  :wink: it looked a lot different to the 8v/VR6 item when it arrived too
