Author Topic: Mk3 tdi Cabrio clutch problem  (Read 1382 times)
Offline nick101
« on: 31 October 2011, 19:09 »
Hi there i have just converted a freinds mk3 Cabrio to run a 1.9TDi,  Got the car running fine the only problem i have is that the new clutch is slipping.  It has had a new 3 peace clutch kit and slave cyilinder fitted.  I have took the box back out and the clutch is fitted fine.  I am wondering if any one has come across or hered of this problem before.  I no there are not many tdi cabrios out there but has any one had a problem when fitting any other engines with hydrolic clutches?
Re: Mk3 tdi Cabrio clutch problem
« Reply #1 on: 31 October 2011, 21:39 »
Did you use a cheap or quality clutch kit. :undecided:
Offline nick101
« Reply #2 on: 31 October 2011, 23:23 »
Genuin vw one
« Reply #3 on: 31 October 2011, 23:31 »
Genuin vw one
Could be a faulty clutch then maybe
Offline nick101
« Reply #4 on: 01 November 2011, 07:34 »
Well thats what i was hoping so i sent it back and tried fitting another one.. Still the same
« Reply #5 on: 01 November 2011, 10:53 »
In that case your looking at a fitment or adjustment issue.
Offline Seanl
« Reply #6 on: 01 November 2011, 14:00 »
Dunno if its different on a TDI, but I didnt use a clutch alignment tool when I fitted mine. Just used a feeler guage with the same amount of spacing in the 4 corners of it. Not had any problems, so dunno if it needs to be 100% perfect, or maybe I just got lucky.  :undecided:
