Author Topic: heated seats, is this normal?  (Read 1015 times)
VeeDubGTI16v
« on: 30 October 2011, 12:16 »
Since owning the mk4 the heated seats have only really worked on the 5th heat setting, with the 4th being barely noticeable and 3,2,1 producing no heat whatsoever. This is also the case for the passenger side so this doesn't indicate it's through wear as the drivers side should be worse. Do the potentiometers wear out in the switched or something? Maybe the leather is too thick?
Does anyone have similar with theirs? it gets bloody hot on 5!
Offline lee gti turbo
Re: heated seats, is this normal?
« Reply #1 on: 30 October 2011, 13:00 »
Had same probs with mine just get new switch and it will be fine will work on all settings :grin:
Offline brothy
« Reply #2 on: 30 October 2011, 17:56 »
I have the same problem, what switch do you mean ?
Offline mcgee9t2
« Reply #3 on: 30 October 2011, 18:00 »
taking it he means the one on the dash to change the level?
VeeDubGTI16v
« Reply #4 on: 31 October 2011, 13:30 »
Great, more expense :laugh:
