Author Topic: Induction pipe  (Read 2177 times)
Offline Ess_Three
Re: Induction pipe
« Reply #10 on: 22 October 2011, 11:34 »
A cold air feed is good...cold air is always good.
But, Ram Air only works on a sealed induction system...so if you go to the trouble of finding the highest pressure area at the front and duct aid from there, you will only see the (small) gain at high speed with a sealed induction system...and holes in the airbox and you lose the pressure.
You can add as much cold air as you want...but any holes in the airbox wing side, bottom or otherwise and you WILL be sucking in warm air as the engine will suck from the point of least resistance.
So a totally sealed airbox is best - except if you hit lots of standing water you run the risk of hydrolocking the engine.
Just ask the owner of my first GTI who hade to replace the engine after a period of flooding!
It's all a balance :-)
..but gaining motorcycles.
Offline mush
Re: Induction pipe
« Reply #11 on: 22 October 2011, 11:44 »
my cold air feed pipe sits behind the bottom right vent on the back so you cant see it at all
the cold air feed pipe is normally silver inside ive just sprayed this black job done and not looking chav
« Last Edit: 22 October 2011, 11:47 by mush »
MK2 golf 16v :-)
VW BUSH
Re: Induction pipe
« Reply #12 on: 22 October 2011, 12:31 »
Could fail an MOT if you only have one working fog light on the front :wink:
Is that right? I wasn't sure about this as mine only has 1 fog working on the front but it passed ok. While researching I read it only needed the fog working on the back and the fog indicator in the cabin?
back on topic, I have my cold air feed cable tied to the passenger side bottom grill :P No idea if it makes a difference as I've never run the engine without it, but it roars like a beast  :evil:
All fitted front lights need to be in working order, swap other fog for reflector and remove/Hide loom if you get any grief from MOT, traffic cops could be a bit more difficult.
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Induction pipe
« Reply #13 on: 22 October 2011, 15:32 »
According to VOSA front fog lights do not need to be in working order for an MOT, the rear fog/fogs is a legal requirement.  I only found this out on Friday due to me taking my VR6 for her MOT.
Offline tweed
Re: Induction pipe
« Reply #14 on: 22 October 2011, 17:31 »
On my old 16v I had hella twins, I took out the center lamp and replaced it with a big trumpet (got it from a data cable box from site) I then got the 8v trumpet from inside the 8v airbox. I got a hole saw same size as that, and then made the original hole on the airbox bigger. I sealed the 8v trumpet to the air box then got a hose to connect the two.
The result was 10mph down a 1.1 mile straight  :wink:
Also had to cut the hella's to make it fit. I didn't mind as mine where cracked and in bad shape.
I recommend this to anyone.
