Author Topic: Questions to sparkies  (Read 2715 times)
Offline Dewey
  • Mk4 1.8t 150 AGU (R-Tech Stage 1 190)
Re: Questions to sparkies
« Reply #20 on: 18 October 2011, 22:01 »
Spur would be better outside the bathroom really, we usually put them outside the bathroom above the door.
Obviously ideal but we either have them with a spur at the main board with a dp switch above bathroom door or in the bathroom on the opposite wall to the bath/shower
So Far - R-tech Stage 1 Re-Map 190hp 225ftlbs, Forge 007P DV, Forge Silicone TIP, Pipercross Panel Filter,  Powdercoated Anthracite Montreal IIs, Custom Cat Back.  Shopping List - Coilovers, Hubcentric Spacers, Front and Rear ARB, Big Brake Set-Up...
Offline golf-sib
  • Турботазик
« Reply #21 on: 18 October 2011, 22:14 »
New question
Also whats the regs now on fitting electric hand rails as most of them have a thermostat switch on them whilst on topic?
Regarding earlier question, I don't have access above the ceiling as its slanted along with the roof, can't even access it through the normal loft due to the heights of the bathroom and roof, only thing I could do is I have an electric shower in the corner which the fan will be 1.8m away from. Any idea's if that could be used somehow?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline chrisowen85
« Reply #22 on: 18 October 2011, 22:28 »
You can't use the shower circuit, any fault with the fan won't trip the fuseboard as the cable to the shower and circuit breaker are far bigger than you need.
Offline Ant1981
  • Feed me, prod me
« Reply #23 on: 18 October 2011, 23:16 »
The fuse in the fuseboard is to protect the cable, not the equipment.
You can use the circuit, but for discrimitation you'll need another fuse or breaker to protect the smaller cable.
'09 Kawasaki Ninja ZX-6R
Offline golf-sib
  • Турботазик
« Reply #24 on: 18 October 2011, 23:19 »
I'll stick with the conduit idea, whats the regulations with the heated hand/towel rails, do they need a pull cord switch or an external wall switch/fuse?
1.8T AGU..
R135
  24
Offline chrisowen85
« Reply #25 on: 19 October 2011, 11:13 »
U need a spur outside the bathroom, doesn't really mater where as long as you can get to it incase of a fault
Offline Ant1981
  • Feed me, prod me
« Reply #26 on: 21 October 2011, 08:33 »
A spur is a method of wiring, it doesn't have to be wired as a spur.
Either use a double pole switch outside or a double pole ceiling pull cord switch.
