Author Topic: 5 to 4 stud adaptors????????  (Read 1843 times)
Re: 5 to 4 stud adaptors????????
« Reply #10 on: 17 October 2011, 23:50 »
What is involved in the swap anyway?
only way is to use cabrio/estate 4 stud hubs (I'm sure you need to change the brakes set up with calipers and the largest 4 stud are 280mm)
I believe if you convert to 4 stud the biggest discs you can fit are 280mm, so that would be the end of your 1.8t dream  :undecided:
Not really, 280mm set up on good quality discs and pads will be fine.
Standard on a mk4 1.8t is 288mm only the Anni's (180bhp) got the 312mm set up.
« Last Edit: 17 October 2011, 23:53 by Wayne »
