Author Topic: help needed...not starting  (Read 1265 times)
Offline dan_apps
  • too low for british roads!
« on: 16 October 2011, 20:28 »
right guys,
summary is auto electrician has ripped all the problematic old alarm and immob out, had to replace the ignition switch after he had finished but she turns over and fuels but no spark. dizzy is fine, coil is fine there even seems to be a slight voltage getting to the coil (whether its enough is a different matter) but it isnt sparking at all, sensors have all been replaced as have the problematic ecu relay, ive checked what i can of the loom behind the glovebox and below the steering wheel but cant see anything odd there.
electrics is my weakest area so any ideas would be greatly appreciated :smiley:
Offline patc
Re: help needed...not starting
« Reply #1 on: 16 October 2011, 20:55 »
Crank sensor, plugs & leads?
PatC
Golf GTI MK3 Anniversary Edition
Offline dan_apps
« Reply #2 on: 16 October 2011, 22:06 »
Crank sensor new a few months ago, HT leads again new a few months ago, plugs are ok too. Any other suggestions? :sad:
Offline javalin
« Reply #3 on: 17 October 2011, 09:11 »
get him back to fix the problem.  Sounds like you've possibly lost the switched live feed?  Does the dash/stereo work?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline dan_apps
« Reply #4 on: 17 October 2011, 19:28 »
well i could james but until the ign switch went i had already shelled out 100 quid for him to sort the alarm etc. no live still there dash illuminates as does car stereo.
anyone think an ECU issue possibly? :undecided:
Offline javalin
« Reply #5 on: 17 October 2011, 19:42 »
doubt it.
Offline 16VWarby
« Reply #6 on: 17 October 2011, 19:46 »
Sorry to hijack dude...
I have a similar problem with my 96 8v:
Drove though a puddle round a blind bend, died. Started eventually but bogged a lot, got 100 yards down road to layby, died, wont start now.
Fuel pump primes and cuts off
Spark out of the coil
No spark at the plugs
So im right in thinking its the hall sender / dizzy?
New crank sensor by previous owner.....
Any help muchly appreciated as im commuting on the trials bike in the morning  :cry:
PS id start a new thread but too many ''wont start threads'' will give some people a minor stroke.  :wink:
Nissan 200sx s14 soon to be 350hp drift machine :D
2007 Golf Edition 30 DSG, weekend toy :D
VCDS HEX-USB+CAN  -  Isle of Man
Offline dan_apps
« Reply #7 on: 17 October 2011, 21:25 »
further investigation and trying to suss this one.
what reading should i be getting from the king lead on the coil on an anmeter?
beginning to think possibly timing is a poss? :undecided:
Offline javalin
« Reply #8 on: 18 October 2011, 07:48 »
you shouldn't be touching the king lead with anything but a spark plug.....
get a Haynes manual and follow the electrical diagrams.  Work out where you have 12v with ing on, and find the missing link.
