Author Topic: Short shift mod Audi S3/TTS  (Read 61568 times)
Offline mkviken
Re: Short shift mod Audi S3/TTS
« Reply #10 on: 23 February 2012, 18:05 »
put the gearstick in between 2nd and neutral and lock in place with a 5.5mm drill bit and to lock the gearbox push down slightly on the shift arm and push the little locking rod (an L shaped type thing) into the gearbox
this locks the transmit ion in service position.
then pull back and twist the locking cable ends a few times to re set the cables and then take out of service position and it should be much better
Golf GTI 7.5 230 white silver
Offline wigit
« Reply #11 on: 24 April 2012, 15:19 »
I tout the Golf R and Rocco R had this so wondered if anyone had the VW part number, fancy OEM rather than putting my VWR one on for a change
Offline RocketRossUK
« Reply #12 on: 14 June 2013, 19:13 »
Not sure what you meant wit the 5,5mm drill piece.
Offline andygo
« Reply #13 on: 04 July 2013, 16:18 »
I locked my gearstick in with a drill bit, but it seemed to be in the wrong place as it was nowhere near a neutral position and after adjusting the cables at the box end, I coudn't get gears 1,3 and 5.
I removed the drill and faffed a bit with the cables. Seems pretty good, although I was doing a bit of enthusiastic driving and it made 3rd and 5th a bit hard to select under braking and a bit of cornering. I was trying out my xds after switching onto the highest setting.
It transformed the car, a bit like a fwd rally car I used to have with a proper lsd fitted.
Offline Gtimk6
« Reply #14 on: 21 October 2013, 10:59 »
Will that short shift fit my 2.0 gti mk6. I need a little help please, if someone can send me links and point me in the right direction. Thanks
« Reply #15 on: 21 October 2013, 13:40 »
Yeah it defo fit mate, call Audi give them the part number and then fitting will take you about 20-30 mins  :smiley:
