Author Topic: New FMDV008 diverter valve  (Read 3167 times)
Offline Yohan
« on: 13 October 2011, 08:51 »
Thoughts and opinions on these?
Tuners, any logs to prove that these hold boost for longer as they have better seals?
Apparently the vacuum chamber is smaller so they react quicker as well?
Offline Yohan
Re: New FMDV008 diverter valve
« Reply #1 on: 19 October 2011, 09:14 »
Response from Forge was
"Hello, the volume inside the top of the valve has been reduced from the OEM Bosch valve and the 007, and also the cross-sectional area of the top of the piston has been increased so the movement of the piston is quicker as the car goes from boost to vacuum. "
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #2 on: 19 October 2011, 17:22 »
I guess the theory is right... :undecided:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 19 October 2011, 18:04 »
Only way to fine out would be do a 1/4mile power run on the dyno and watch the shift points, as all the dv is doing is making the shift much crisper,  the oem N valve is good for a 300+bhp power run and will give the same results as the 007p, but the 007p is much better in the lift off shift area.
I will order one tomorrow and play with it on a few customers car.
Nick
 01455 617233
Offline daz veedub
  • Operation 1.8t bolf
« Reply #4 on: 19 October 2011, 20:48 »
be good to see the differences between them
Offline Yohan
« Reply #5 on: 20 October 2011, 07:29 »
Nick
Could one of the customers cars be mine please :grin:
Would be interesting to see what mine does a 1/4 mile dyno run in....Can you do an estimated 0-60 of mine as well?
Offline shaft69
« Reply #6 on: 22 October 2011, 11:36 »
I was in awesome gti yesterday on my lunch hour tried sell me 008 bought 007 with awesome logo on instead.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
