Author Topic: Difference between IAT sesnor and Coolant temperature sensor?  (Read 2320 times)
Offline Gabriel2202
I know this sounds really dumb, but im new engine work and have been told that changing my coolant air temperature senor may be the cure to low mpg.... I have been looking for parts online and euro car parts only do an intake air temperature sensor (which looks the same and is green 4-pin push in like the coolant air temperature sensor is). I thought the IAT sensor was threaded near the throttle body? whereas the CAT sensor was the green 4-pin push in to the right of the engine?  :undecided:
Am i right in thinking this? Could someone set me straight on this please on the differences?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline javalin
Re: Difference between IAT sesnor and Coolant temperature sensor?
« Reply #1 on: 12 October 2011, 16:14 »
I think you mean changing the "coolant temperature sensor" or "CTS" which has a large amount to do with fueling.
The "Intake Air Temperature" Sensor (or IAT) which measures intake air temp has very little impact on the fueling.
What car?  On the mk3 its a push in with a clip.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Gabriel2202
« Reply #2 on: 12 October 2011, 19:03 »
James
Ah yeah, cheers, that'll be what i mean  :embarassed:.... sorry should have put its a mk4 golf 1.8t... I have changed the lambda sensors and the MAF which made a difference but its still very low! So going to try changing the CTS but both the IAT and CTS i have seen photos of on euro car parts and the bay look exactly the same though??
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline javalin
« Reply #3 on: 12 October 2011, 19:50 »
goto VW, http://www.vwspares.co.uk/g4cooling.php or GSF - don't bother with ECP
Just change the CTS for the time being too - IAT won't be causing it.
James
Offline Gabriel2202
« Reply #4 on: 12 October 2011, 19:59 »
James
Great, thanks for all your help mate  :grin:
Golf IV 1.8T AUM
Golf V GT TDI PD170
