Author Topic: Gti_Jamo's White Mk3 Golf Gti....HOME WITH NEW PICS!  (Read 207244 times)
Offline BISSONE
Re: Jamo's Mk3 Gti 8v Winter Rebuild Project
« Reply #40 on: 03 November 2011, 21:31 »
Wow! You have been busy, your setting the bar quite high there lol. Did you have any issues removing the subframe? Any siezed captive nuts? Fair play though its coming along great fella!
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #41 on: 03 November 2011, 21:39 »
Cheers, yeah I sometimes wonder what i'm doing but the progress has been good and not spent much on it yet so i'm happy. Subframe bolts came out no bother. Wishbone bolts were a bit tight and the top nuts on the shocks took me ages to get off.
Offline Gti_Jamo
« Reply #42 on: 06 November 2011, 14:56 »
Anyone know the part number of the clip that holds the pin on the servo into the brake pedal? Its a white plastic clip and it partially broke when removing.
EDIT - Not to worry. Found what I need!
« Last Edit: 11 November 2011, 21:55 by Gti_Jamo »
Offline Gti_Jamo
« Reply #43 on: 11 November 2011, 22:09 »
Few more pics of todays progress.
Basically just sanding down and treating the surface rust. Nothing too major. Had already removed all the wax with a heat gun.
As for the backs of the inner wings instead of removing all the seam sealer down to the metal I have removed it where it has lifted due to rust, treated the rust and reapply sealer then will be some stonechip then paint. Will adopt this way when I do the underside.
Offline BISSONE
« Reply #44 on: 11 November 2011, 22:24 »
Looking good matey, Are you planning on any smoothing in the bay or just giving it a freshen up? Good work tho as usual!  :cool:
Offline DanChave
« Reply #45 on: 11 November 2011, 22:45 »
Great progress so far :)
Offline Gti_Jamo
« Reply #46 on: 11 November 2011, 23:31 »
Cheers mate, no want to keep it all original looking but will weld up the odd obsolete hole here and there.
Offline sharki786
  • GOT BOOST??
« Reply #47 on: 11 November 2011, 23:44 »
just read the whole thread. gota say:
YOU DA MAN :smiley:
keep up the work!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mumbles
« Reply #48 on: 12 November 2011, 11:46 »
Brilliant work mate. Will be keeping an eye on this one  :cool:
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline Murph
  • Mk3 Nub Dub
« Reply #49 on: 14 November 2011, 16:26 »
nice work bro, loving the thread, im here regularly :)
as per previous posts, i wish i had a garage this size lol!
keep up the good work
