Author Topic: BRAD & BENS, ***NOW 1986 CADDY PICKUP 1.6 TO 20VT POWWAAA !!  (Read 78983 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: BRAD & BENS, ***NOW 1986 CADDY PICKUP 1.6 TO 20VT POWWAAA !!
« Reply #110 on: 11 December 2011, 19:28 »
Cheers mate
back down working on the Caddy Wednesday nite  :smiley:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #111 on: 10 January 2012, 21:47 »
Right, this car is almost completed now as i got some monet off the owner for parts
i have not got my pics yet but ill update with all those on the W/end
Engine was removed and he painted the bay Black
Iv since put the engine back in, and wired un the OEM loom and ECU
Few bits still to do, cam belt, mk2 16v tensioners, intercooler pipes etc.. then the mk2 16v clocks need wiring in, Mk1 GTI driveshafts, G60 brakes etc
As i say.. will upload pics on the w/end.
Need to finish off this project now because iv just bought a AUQ 180 BHP engine to fit into my Dads Mk4 GTI 2.slow
Then we have a Camper van conversion on the cards too..
Offline travisreeve
« Reply #112 on: 11 January 2012, 01:11 »
Sweet dude  :grin:
wounderd were you had got to with this. Glad to hear its going well
Offline DanChave
« Reply #113 on: 11 January 2012, 08:53 »
Looking forward to the pics Brad :) Keep it up you guys :)
Offline Andyfloss03
  • "You Muggin Me Off Infront Of My Pals?"
« Reply #114 on: 11 January 2012, 12:31 »
EPIC READ :)
Offline dom
  • Back in a Mk4
« Reply #115 on: 12 January 2012, 08:53 »
Good to hear it's almost done, needs pics though :wink:
Offline F17BAD
« Reply #116 on: 14 January 2012, 19:39 »
Right, a few pics, not many as theirs loads on the guys phone who owns the caddy which ill get when i get chance.. I am extremely busy at the mo with my music, DJ work and Cars.. and currently in process of sorting the AUQ engine for my Dads 2.slow
Got Sump of the AGU, did the pick up pipe.. was most blocked iv ever seen, lost the picture but trust me it was as bad as it gets... I'm surprised the old K03 the engine had didn't go poooop!!
Advise anyone with 1.8t 20vt to do the pick up pipe, we do this as standard procedure
sump was full of sh!te too
cleaned it all out
worked on the wiring, everything is plumbed in engine side, apart form 1 plug thats old square style on the loom i have, and the Alternator is new oval style, so just need to source a new style connector and swap out the plug
inside i have got all the wiring done apart form a few wires which ill do next week, got dash back in and once iv finish the last few wires ill tidy it all up and fit the remaining trim parts of the dash (this is a replacement GTI dash we sourced)
I am using MK2 GTI 16v 160MPH clocks so we had to modify the looms to make these work..they are twin plug where as the Caddy was single
Refurbished the G60 brakes, used genuine repair parts from VW (Not cheap)
Ben has been tussling with the GTI driveshafts, having a mare with broken split pis and other annoying expected crap on the caddy (he was also nursing a huge hangover from hell which did not help matters)
More pics on this later, but here is one of the GTI Driveshafts we sourced (genuine VW item)
Decided to keep the coolant bottle as a MK1 GTI item so i sourced a brand new one with cap
Need to do same with he window wash bottle
Engine is now home for good.. once the final bits have been completed (next week), i will wave my magic cleaning wand over it all one final time before the keys are handed over to the owner for good
Here is how she looks at present
« Last Edit: 14 January 2012, 19:43 by F17BAD »
Offline bobbarley
  • I'm kind of a big deal...
« Reply #117 on: 14 January 2012, 19:56 »
Can't believe I have only just spotted this thread!  My hat off to both of you guys, you're doing some amazing works, looks first rate! :afro:
Where's the air intake on that caddy/AGU?
Offline F17BAD
« Reply #118 on: 14 January 2012, 20:05 »
Air intake is not fitted iv removed to clean etc, but sits same as all other 20VT engines top right  :smiley:
cheers for comment too :smiley:
Offline bobbarley
« Reply #119 on: 14 January 2012, 20:29 »
Does the owner want anything doing about the suspension/handling etc to avoid it powering off into a ditch or something?  :grin:
