Author Topic: loom for engine swap  (Read 1114 times)
Offline truff
« on: 25 April 2005, 14:53 »
may be a no-brainer but when putting an injection engine to a carbed mk1 would i only need the engine loom or the whole car loom its just looms are a b!tch to fit for me and ild prefer carbs (twin webbers) but these are pricey a what to do on as little cash as poss. also does an audi two litre fit in with the satndard mounts and manifolds cheers
Offline richandhazel
Re: loom for engine swap
« Reply #1 on: 28 April 2005, 13:35 »
You're going to need more than just the egine bay loom. For a start you have the electric fuel pump at the back there, carb has a mechanical pump. Then there is the fuel pump relay, so you'll need that relay and associated wiring. Best way to tackle this project would be with a donor vehicle. Failing that, stick with the webers.
Offline truff
« Reply #2 on: 04 May 2005, 11:10 »
cheers for the help
