Author Topic: GTI cutting out, oil light flashes  (Read 270997 times)
Offline avant aclue
Re:GTI cutting out, oil light flashes
« Reply #30 on: 17 December 2003, 19:57 »
I don't know whether to laugh or cry. Our 8v 2.0 Cabriolet has picked up this annoying trait of dying after about 5 miles and a local VW specialist was bewildered by it, the main dealer, Spirit in Banbury, has had 4 attempts at it and got nowhere near it.
I joined this site specifically to try and sort it - I thought it was just us!
Good news - we're not alone
Bad news - NO-ONE knows the bloody answer....
Well at least there are some good tips here - somewhere to start I guess. I'll try and keep you posted with my success - or lack of it.........
golfvr6
« Reply #31 on: 17 December 2003, 20:45 »
Airflow meter or coil pack maybe, or cam sender, or engine speed sensor. Any of these SHOULD show up on a fault reader.
Offline jaseb
« Reply #32 on: 17 December 2003, 20:53 »
No the garage I took it to used a VAG (is that what there called) didn't come up with anything. If this is such a common problem how can no VW garage have an answer??
The thing is like I said I replaced the fuel pump relay and it was good for two weeks but then it started backup again?
It frustating just before crimbo as well sod's law >:(
Offline Scott
« Reply #33 on: 18 December 2003, 09:44 »
I had mine fault-code read and all it threw up was an ABS fault (light was coming on occasionally - code clear sorted it), no other codes at all came up. Apparently if it was a dodgy hall sender, the code may not even come up unless the diagnostics machine was plugged in when it actually cut out! and I'm not paying ?29 an hour for a mechanic to ride around with me until it does cut out!
My coil pack did fry itself 6 months ago, but was replaced, so should be OK.
jaseb - don't s'pose you have the fuel pump relay part No.??? Your cutting out sounds exactly the same as mine in terms of timing. Usually after 15 mins (same spot on A14 usually) and around 76-82 degC oil temp - although this may not be inportant. Does yours just cut out for a fraction of a second and bump-start itself again?
Mk4 PD150, Jazz Blue, nice! Puts my old Mk3 Gti to shame
Offline jaseb
« Reply #34 on: 18 December 2003, 10:30 »
I haven't got the car at the mo i'll have a look for the part number and post tonight but the relay is number 167 its on the right hand side when you look up top row, I haven't noted what oil temp is but yeah it cuts for about half a secound most of the time then sometimes it just cuts totally out then the oil light flashes.
I'm not driving it at the mo its getting too dodgy cut out on me halfway across a roundabout the other day, I going to give the throttle housing and everything a proper clean out this weekend.
Offline avant aclue
« Reply #35 on: 18 December 2003, 16:54 »
Just for info, I put this query on www.VWmonline.co.uk and got a response suggesting I replace relay 109 in position 3 of the relay board. Without a manual that means nothing to me - is that a fix familiar to anyone else, or is it the same as replacing the "hall sender unit"?
Offline jaseb
« Reply #36 on: 19 December 2003, 14:12 »
The part number for the Fuel Pump Relay is 191 906 383 it will cost you around ?16, post if this works
Offline toddy98274
« Reply #37 on: 21 December 2003, 14:45 »
I also have this problem and it is becoming progressively worse.
It has now got to the point where not only do I have to get up at 6 in the morning in the freezing f***ing cold but when i do my 8v will not start at all.
I had the AA out the other day to have a look for me and all he could suggest was cleaning the plugs and ht leads.  Which to his credit worked temporarily.
I am going to try replacing the fuel pump and ecu relays as mentioned and will post any advancements.  However, my symptoms seem to be slightly different in that it only happens now when it is wet.
I was wondering whether this may be due to a dodgy seal or the like, any suggestions would be appreciated.
Offline Gary17
« Reply #38 on: 21 December 2003, 17:10 »
hi mate i have had this problem for a couple of months now and has got that bad i cant drive it any more !!! i have tried allmost everything but i think it could be the air flow meter ! i have been looking for a second hand one but no luck. a new one is about 350 quid i will let you know if this works.
golfvr6
« Reply #39 on: 22 December 2003, 00:16 »
Maybe damp getting into the ht's. Try a new set of leads and plugs.
