Author Topic: GTI cutting out, oil light flashes  (Read 271154 times)
Offline dobbin123
Re: GTI cutting out, oil light flashes
« Reply #120 on: 21 March 2005, 21:50 »
Thanks Guys for the info will replace my one ASAP and see how we go  :grin: hopefully this car (our first VW) will get some good miles under its belt
Offline kr1s77
« Reply #121 on: 22 March 2005, 11:58 »
got a #30 relay yesterday from ECP ?10.03 Gray and made in germany. Put it in and it drove like a dream? :grin:. Straight away i could the difference, car felt smoother, queiter and more responsive.Also the mpg went up to 36 from 30.
However, this morning on the way to school (dropping the kids off) it cut out again? :cry: and the mpg stayed at 30.
ASV 1.9 TDI 110
Offline gavcradd
  • Faustus - none hit wonders
« Reply #122 on: 05 April 2005, 12:29 »
I had a problem with the MAF causing juddering on my P reg GTI 2.0 8V for about 3 months, and in the last month of this, it also started to cut out when I stopped at traffic lights, etc. I changed the MAF yesterday, which fixed the judder, but the stalling still remains.
I don't get the oil light coming on, and it never stalls at speed, so I think I can count out the relay. However, would I be correct in assuming that running with a knackered MAF for 3 months may mean that my throttle body is probably caked up with crap? I'm going to try and give it a clean out in a min, although I don't really know where to start...
I'll try and get some photos!
www.faustus.co.uk
Offline gavway
« Reply #123 on: 06 April 2005, 19:13 »
Maybe you guys can help me my 8v mk3 GTi cuts out when cold if left at idle. Sometimes its okay on start up but very rarely. Can be quite dangerous when you dip the clutch at a roundabout in rush hour traffic as you lose all power steering when the car stalls.
The fault goes when warm any ideas relay etc???
(there is no fault code)
Offline kr1s77
« Reply #124 on: 09 April 2005, 08:16 »
i cleaned the throttle body the other day and so far it drives ok  :grin:. So i would suggest doing that first as it wont cost anything apart from time and effort!!
ASV 1.9 TDI 110
Offline salty
« Reply #125 on: 10 April 2005, 18:42 »
My P Reg 16V is juddering in normal driving, sounds like gavcradd's problem, can someone tell me what a MAF is, and where do I get one? Thx
Offline dobbin123
« Reply #126 on: 17 April 2005, 20:00 »
Got the Grey relay 30 fitted and idle speed now stays nailed at 1000RPM however short drive later cold engine slowing dowm in second cut out revs dip away needle bounces and ignition lights come on
Ant other ideas anyone also What does IN02 mean is that the Service indicator?
Offline djhectic
« Reply #127 on: 13 June 2005, 16:06 »
my mate who was a vw tecnician a few years ago had the same problem on his vr6,he replaced all the ususal items to no avail,he eventialy traced the problem back to the oil presure switch on the oil pump.
Offline gerty31
« Reply #128 on: 24 September 2005, 12:24 »
Hi all
after reading the this thread (and the ones linked 2 it) i now have a list of several things it could be that cause this cutting out issue....
Of them i have changed the ECU relay, to no avail (car cut out on breaking 2hrs after installing it)
I was wondering what to try next as im not keen on getting ripped off by VW - especially as they dont really seem to know the actual source of the problem...
there seems to be a good shout for this Ecotek power boost or cleaning the throttle body..? just wondering if anyone has actually ever fully solved the problem...?
cheers
Offline daz123
« Reply #129 on: 28 September 2005, 18:34 »
Hi all
cheers
clean the throttle body outwere the butterfly open,s and shut,s. my +car used to stall at every junction cleaned it out and it,s been fine ever since
