Author Topic: golf 1.8t not running right think induction ?  (Read 3869 times)
Offline james2
  • No scammers please.
Re: golf 1.8t not running right think induction ?
« Reply #10 on: 03 October 2011, 20:01 »
+1 as above i did the same ,much better and sounds good.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline golf-sib
  • Турботазик
« Reply #11 on: 03 October 2011, 21:31 »
Wrap it!
Along with all the other aluminum as that has brilliant heat conduction properties. I'm running a long tube and not having any problems. But I have pipercross panel filter in the air box with a 2.25" pipe coming out the airbox and coming out just under the horns.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline james2
« Reply #12 on: 03 October 2011, 21:45 »
copy mine and daves setup ,you will love it and wont go back to panel filter or induction kit by horn.I tryed both ares are much better.Try it you can easy put it back to your horn with a silcon joing pipe.But get a new filter the ones that come with the ebay kit is only a £9.99 filter crap and is 2 big to put next to battery. :wink:
Offline golf-sib
  • Турботазик
« Reply #13 on: 03 October 2011, 21:48 »
Would of thought there would be loads of heat intaking that high and far back by the engine?
1.8T AGU..
R135
  24
Offline james2
« Reply #14 on: 03 October 2011, 21:57 »
Try it, the sound rules  :grin: i use a jr filter from france got it second hand never used £30(rated 250bhp)  :drool: get a cold air feed from bumper vent were your arce filter sits .Ill find my video i think i put all the air filter sizes in desciption .I wanted a green need a open end filter not sealed if you know what i mean (has a extra filter in the end). :wink:
« Last Edit: 03 October 2011, 22:07 by james2 »
Offline james2
« Reply #15 on: 03 October 2011, 22:02 »
 20 degrees offset, Size in desciption. http://www.youtube.com/watch?v=RO8zgB8U670 Dont knock the video filmed by xbox 360 camera :grin:
Offline Dave_IOW
« Reply #16 on: 03 October 2011, 22:16 »
Ive said this before, but some would argue that cooler air after the turbo is more important.
Im pretty sure my intake temps would be lower due to a FMIC than a induction kit in the vent with standard IC.
Turbo's superheat any air that passes through them, i know the colder the better to start with and all that but meh..
I have a cold air feed running to mine and i doubt theres hardly any difference tbh.
The alu pipe coming from turbo to intercooler = hot,
the alu pipe coming from intercooler to inlet = cold.
Longer pipe and much slower throttle response was worse than a couple of extra degrees intake temp.
Nuff said i reckon  :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline golf-sib
  • Турботазик
« Reply #17 on: 03 October 2011, 22:34 »
We will have to get my Turbocharging formula book out as we need to calculate underbonnet temperatures and chuck an ambient air temperature in  with a turbo compressor efficiency of 75%  :grin:
Wouldn't have thought pipe length leading to the turbo would off been a restriction in a forced induction setup, after the compression I can see it being an issue due to the volume off air needed to be filled followed by pressurizing.
1.8T AGU..
R135
  24
Offline Dave_IOW
« Reply #18 on: 03 October 2011, 22:39 »
Lol im not too hot on the theory behind it, but i know for a fact that when i had the long pipe on and filter behind vent, i had a VERY slow throttle response which is what the original poster was on about!
Im VERY happy with mine where it is, and im sure he will be too!
Try it bud, filter on the tube end, then directly on MAF, amazing difference!
Thats why i think i have a happy medium, far enough away and with cold air feed so it gets reasonably cold air, but short enough for rapid throttle response!
Just my 3p
Offline golf-sib
  • Турботазик
« Reply #19 on: 03 October 2011, 22:43 »
3p, crikey you have some weird change   :tongue:
Will give it a go once golf is repaired, been working like a mule and another 2 weeks to go  :sad: plus trying to sell things to get some money to repair the golf. Will give it a go as I have loads off aluminum piping laying around that I could do with selling some.
You got any videos off that exhaust as I am debating it  :smiley:
1.8T AGU..
R135
  24
