Quote from: Agreeable Slick on 30 September 2011, 12:25Quote from: Dan n Nic on 30 September 2011, 12:15Why then do some car manufacturers including VW will state not to use supermarket fuel?Who do you think they develop the car with? They aren't going to nip down tesco and buy 500 litres of unleaded to test the engines on are they. I would it's cheaper
Quote from: tech1889 on 30 September 2011, 12:28Quote from: Agreeable Slick on 30 September 2011, 12:25Quote from: Dan n Nic on 30 September 2011, 12:15Why then do some car manufacturers including VW will state not to use supermarket fuel?Who do you think they develop the car with? They aren't going to nip down tesco and buy 500 litres of unleaded to test the engines on are they. I would it's cheaper Are there not different "grades" of fuel though?
Quote from: Agreeable Slick on 30 September 2011, 20:16It comes out as 95 through fractional distillation and cracking. Ethanol or Methanol make it stronger normally. Additives are usually a % of antifreeze, or in diesels case a non emulsifying agent. Good enough for you? I wasnt having ago mate, just curious is all So if i put methanol in my tank it would increase the octane?
