Author Topic: New Toy (Bluetooth)  (Read 10154 times)
Offline ajmoir36
Re: New Toy (Bluetooth)
« Reply #20 on: 29 September 2011, 22:00 »
Only rSap enabled phones with support SMS (mainly Blackberrys and Nokia's).
The colour of the phone screen is fixed to green too and can't be changed.
Also the voicemail in memory slot 1 is hard coded and can't be changed ( I had the same frustration )
Thanks figured so.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline p3asa
« Reply #21 on: 29 September 2011, 22:47 »
Mine can be reconfigured but that might be because its the Fiscon unit?!?
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #22 on: 29 September 2011, 23:19 »
Plus you'd need an external antenna if you were able to use rSap?
Mine has an external antenna and gives texts in the MFD and reds them out etc, also works with rSap on my Nokia 8800 arte and kit works with my iPhone 4 but not texts or rSap - anyone any idea which kit I have as I'd like the same for Mrs Docs Tiguan  :wink:
Thanks and sorry for hijacking
Offline ajmoir36
« Reply #23 on: 29 September 2011, 23:30 »
vcds will tell you the part code.
Offline AndyC
« Reply #24 on: 30 September 2011, 00:00 »
How you finding your Fiscon?
Ive had myn removed by the fitter yesterday.
Every person who called me was receiving feedback.
Previous:- Pearl Black Golf GTI MK5
Previous:-White Golf GTI MK6
Currently:-White Golf R
Offline The Doc
« Reply #25 on: 30 September 2011, 06:45 »
Not using an iPhone 4 are you Andy? I had some fun and games with my iPhone 4 on mine.
Offline mortygt140
« Reply #26 on: 30 September 2011, 06:46 »
Craig your kit is the 3C8 035 730A unit There 5N0 035 730D is the same unit and can be had cheaper now from Ebay, roughly £95-£100 you would just need the wiring loom.
Darren
Offline The Doc
« Reply #27 on: 30 September 2011, 08:26 »
Darren
Thanks mate  :wink:
Offline skandar
« Reply #28 on: 30 September 2011, 10:38 »
Right got it finished, took me three hours (which included a ensure theres no rattles test drive), lucky it was nice and sunny.  A few coding issues too (or should I say a few things to code).
The radio trim was very tight, I must have spent a good 30 minutes being careful not to break a single clip.  Roof trim came down easily, and microphone clipped in ok, fed the mic wire across the roof to the visor light hole, once the light was removed.  No need to a ruler or wire it seemed like there was loads of space, just waggled it around until I snagged it in the hole.  Removed the jesus handle and lowered the roof lining to get the wire out by the door, then fed the wire down the back of the A pillar trim (next to the windscreen) to avoid the airbag, without removing the A pillar trim.  Fed the wire down the gap in the dash between the A pillar and the dash, then down past the fuse box and along into the radio bay.  Fed the bluetooth module wire along the dash to the fusebox and then down the side trim removing the edge between the dash and the door pillar.  Then along the sill trim which I pulled up to unclip three of the clips that held it on the sill then under the carpet to the airbag wiring hole where it popped out and plugged into the box under the seat. Unplugged the blue media connector and inserted it into the bluetooth wiring breakout.  Shoved all the wires in the hole and slide the radio back in. Gosh that makes it sound easy.  There is surprisingly a large amount of room to get arms, fingers in.
Then VCDS:
1. Gateway (19)/Coding (7) - Enabled 77 in the long coding helper for telephonics. (Coding E9807F06100 6 12000003 there are no gaps the 6 used to be a 2)
2. The telephone module (77)/ Coding (7) had to change to English UK (2) instead of English US (A), had to disable Mic fault diagnosis and the control module diagnosis, also had to change the 3 button controls to inactive as I do not have the roof controls.  This removed all three fault codes. (Coding 0200000000010101 I think the last number might have changed to a 0 to remove the 3 button inactive not sure that I had it recorded correct in the logs.)
3. Steering Wheel (16) / Coding (7) - Had to change the 5 to a 7 to enable the voice commands button on the steering wheel (Coding 0000732 the 7 was a 5) I have cruise control.
Either way it seemed to work with my Samsung Galaxy S2 although it read the contacts out the phone book using the radio is gibberish (well the names are ok but the numbers are crap and it fails to dial all of them).  Although if you use the DIS screen in the dash it works perfectly (weird).  Had to pre-program the 5 memory slots, cant get rid of number 1 annoying as I dont have a voice mail. (any ideas?).  Also cant edit the phone book manually to sort the numbers on the radio (annoying any ideas?)  Voice dialing can manually be added using the DIS by tagging contacts with a voice command.  If you just say something it that isnt tagged it attempts to make the best guess.  I tried Mum and Dad and they both retrieved them in a list to select. Impressed.
My mum sent me a text to the phone and it tried to send some bluetooth audio as it came up on the screen enable bluetooth audio which I did.  Then nothing happened. Although looking in the phone I have just found a driving mode, which can using bluetooth audio read emails, text, accept commands and facebook people, with loads of other things.  So it will be interesting if I can get the phone to do this using the bluetooth module.  I think there will be some playing tomorrow.  Either way I couldn't find anything in the system for SMS messages so can only assume it doesnt do them.  Not sure why the phone is green and white on the display either, since everything else is Red and white.  (any ideas?)
Great job mate...
This is getting me excited to work on mine... can't wait... :nerd:
questions..
- did you have to swap the mic connectors for RCD510 on the wiring loom as showed on the pdf manual on the previous posts?
- voice control works on RCD510??...
- was the length of bluetooth wire btween module and radio sufficent?
to answer your question earlier, no I was not bidding 10 days ago..haha
MK6 GTI 5Dr | DSG | Leather | 18" Monza Shadow | Reversing Camera | RNS510 | VW OEM Bluetooth | Parking Sensors Front & Rear | Reflex Silver |
Offline AndyC
« Reply #29 on: 30 September 2011, 11:38 »
Yeah Doc i am using an Iphone 4, but I also tested it with my Nokia 6330 and still the same.
The fitter blamed it on the Alpine Imprint Im using with my stereo, so it was a choice of remove the Imprint or
Fiscon.
The Fiscon had to go :angry:
