Author Topic: Calibra yellows and 3" maf - slightly rough running  (Read 5800 times)
Offline Chris.
« on: 25 September 2011, 19:10 »
Car is a r-tech stage 2 custom mapped car AGU with everything upgraded.
Put a set of calibra yellows in other day and a 3" maf to unleash a bit more power prior to map tweaks.
All good, just a tiny bit hunting idle and we only talking a few rpm's but seems more noticable from the exhaust at the back.
Boosts to 20-21psi peak and occasionally holds the boost at 20psi for a few hundred rpm then holds well throughout the rev range, sometimes at 13-14psi at redline from a quick glance at the guage.
HOWEVER...... there is a occasional/pretty often misfire at about 3250-3750rpm where the engine kind of splutters, not as if the wastegate is being pushed open, just what seems like a ignition issue, just like what it was doing on the denso ik22's but a bit less harsh. That is when the boost is at 20psi.  Anywhere after 4000rpm and theres no misfires.
Was told it smells a bit rich, which is understandable, especially when booting it down the road.
Also feels like the power is a lot more at the top end of the rev range now.
Havent had any chance to do some logging, but inform me what blocks I need and will happily supply them.
Saves messing nicks feedback thread up!
Click For Build Thread
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Calibra yellows and 3" maf - slightly rough running
« Reply #1 on: 25 September 2011, 22:08 »
Have you used your old maf sensor in the 2.75" id housing? or just used the sensor that came with it?
 01455 617233
Offline Chris.
« Reply #2 on: 25 September 2011, 22:08 »
Got the old 20v AGU maf sensor in there.
Offline RTechUK
« Reply #3 on: 25 September 2011, 22:15 »
Do a run or two with the rail pressure static at 3bar with the vac line to the fpr disconnected to see if it cleans up the 3250-3750rpm hickup. If it cleans it up then its the part load map which we increased on thr last map session causing a rich missfire.
 What happens when you inrease the power linear on the throttle, instead of going to wot straight away?
 01455 617233
Offline Chris.
« Reply #4 on: 25 September 2011, 22:16 »
If its NOT wide open throttle straight away, its fine, after 4000rpm, WOT is perfectly fine and pulls pretty hard to redline (near enough)
Will get a run done with the FPR disconnected and see what it does.
Any blocks in vagcom that will assist?
Offline Chris.
« Reply #5 on: 26 September 2011, 21:39 »
tested with no FPR vacuum today.  Misfires like anything even on partial throttle, so disconnecting that definately made it a lot worse what with it connected.
Does sound decent though.....sounds like it has anti lag and is cammed to death on idle, especially cold start :)
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #6 on: 26 September 2011, 22:13 »
Excellent stuff, I have mine on the way and also a refurb kit for them so will get cracking. My mate found a 3" MAF housing without a sensor that he's just given to me so happy days  :cool:
Offline Chris.
« Reply #7 on: 26 September 2011, 22:14 »
Nice, managed to get mine stuck into the original k03s turbo intake pipe.  Needed to grind the maf down a bit to make it thinner, but it fits.
Offline RTechUK
« Reply #8 on: 27 September 2011, 13:04 »
It sounds like its not liking the 16x16 Lambda at part load map, which was custom set to your last setup, in the past the yellow/3" setup worked well out the tin.
Just needs custom mapping to the yellows imo.
 01455 617233
Offline Chris.
« Reply #9 on: 27 September 2011, 13:53 »
Spot on!  Bound to be out at somewhere as injectors are quite a bit bigger.
I'll get some cash built up and get her booked back in for tweaks :).  Anything else you recommend fro current setup? Or not really worth it for gains?
