Author Topic: 17" Steel wheel?  (Read 4481 times)
Re: 17" Steel wheel?
« Reply #10 on: 23 September 2011, 23:23 »
I pass my MOT with the wrong size spare in the boot.. But i guess thats not something they check  :tongue:
This is all a bit off because where you think 5mm is nothing.
If I use the calculator it says my current width is 592 with 205/40/17
But my spare is 632 with a 205 55 16
6% difference. And its says there should be 2.5% difference max!
Ive got a spare 205/40/17 tyre so i just need a 17" wheel with 5x100   :smiley:
Your running the wrong size tyres at the moment hence why your speedo is out.
205/50/17 or 225/45/17 is what you should have fitted.
Offline thatwillis
« Reply #11 on: 23 September 2011, 23:55 »
Truee makes it lower tho. Whilest only being lowered 50mm (insurance wise)  :tongue:
« Reply #12 on: 23 September 2011, 23:57 »
Makes little difference tbh but it is cocking your gearing and speedo up, also have you checked your insurance companies view on undersized tyres being fitted. :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 24 September 2011, 09:37 »
width isn't the issue, it's the profile that affects the speedo
Offline thatwillis
« Reply #14 on: 24 September 2011, 10:25 »
Yeah true indeed
My speedo shows me as going faster than i am. Which means I'm less likely to get caught speeding.. this theory :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 24 September 2011, 10:31 »
true, speedos tend to do this anyway though
Offline Tazzy
« Reply #16 on: 24 September 2011, 11:55 »
modern speedos are out as standard
theres a website that you input the details of your car, put what size wheels you have and it will tell you what size tyre you need, also tells you if youre changing size wheels that how much your speedo will be out by
« Last Edit: 24 September 2011, 11:57 by Tazzy »
If It Comes Off, Modify It!
Offline earlymk2
« Reply #17 on: 24 September 2011, 20:37 »
My anni has 18"s from the factory and has a 16" spare.
Offline dazzifumi
« Reply #18 on: 24 September 2011, 23:46 »
take the spare out and carry a can of tyre weld and stop being gay worrying about your spare wheel
« Reply #19 on: 25 September 2011, 00:04 »
Same as mine then, 225/40/18's with a 16" spare
