Author Topic: difference between 8v and 16v box?  (Read 1322 times)
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« on: 22 September 2011, 18:14 »
the synchro has gone between 3rd and 4th so i'm looking to get a recon box...
i spoke to a guy who sells recon units and apparently cause mine has 28 splines for the clutch that means it's a 16 box, is that correct? if so would it make my car more aggressively geared? because i swear the ratios make it much quicker than it should be, it really does fly :P
Re: difference between 8v and 16v box?
« Reply #1 on: 22 September 2011, 23:37 »
Yes 16v was a bigger shaft from memory, not sure how many splines
You may also find yours has a TD box maybe.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 23 September 2011, 10:49 »
Somewhere...and at this moment I can't remember where I saw it, there is a list of all VW gearbox ratios.
« Reply #3 on: 23 September 2011, 10:51 »
Eureka!
Not exactly what I saw, but good none the less.
http://www.brokevw.com/020ratios.html
