Author Topic: 1.8t 150 remap  (Read 4868 times)
Offline Kus
Re: 1.8t 150 remap
« Reply #10 on: 23 September 2011, 07:43 »
SEARCH BUTTON!!!
Offline rio_gti
Re: 1.8t 150 remap
« Reply #11 on: 23 September 2011, 10:26 »
am i being a bellmet or am i right in hearing that when u get a revo map (or trial  :undecided: ) it locks the ecu and is a nightmare to remap by another company after??
also i heard that the revo's are a real aggressive map, sot a nice, smooth curve  :rolleyes:
Re: 1.8t 150 remap
« Reply #12 on: 23 September 2011, 10:42 »
am i being a bellmet or am i right in hearing that when u get a revo map (or trialĀ  :undecided: ) it locks the ecu and is a nightmare to remap by another company after??
also i heard that the revo's are a real aggressive map, sot a nice, smooth curveĀ  :rolleyes:
Correct on both counts, one of the reasons I did not use them.
Offline dom
  • Back in a Mk4
Re: 1.8t 150 remap
« Reply #13 on: 23 September 2011, 22:12 »
I have also heard that when the Revo trial expires it has been known to cut the power back to below stock level therefore making the difference between standard/mapped appear even greater :lipsrsealed:
Offline The Doc
  • E63s Estate - Vito Sport
Re: 1.8t 150 remap
« Reply #14 on: 23 September 2011, 22:25 »
Can't always believe everything you hear and one mans water is another mans wine.....
Go trial one yourself - you have nothing to loose and it's free - then you can make up your own mind - don't let us lot brainwash you - then if you don't like it go for a tour of the forum traders as I'm sure they'll let you try their remaps too  :wink:
« Last Edit: 23 September 2011, 22:41 by The Doc »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: 1.8t 150 remap
« Reply #15 on: 23 September 2011, 22:53 »
The trial tuned fuel and ignition maps stay in play but the main load request seems to be lower on the revo trial stock condition vs a full oem stock map. A stock AUM will make around 154-159bhp where the stock Revo map will kick out around 147-150bhp.  I dont think it was an intension to run lower load, but just to get there stock map as close to 150bhp with there fuel and timing stratergy.
A Revo/APR maps can lock ME7 ECUs out to read and write on older map versions, but the lastest map versions seem to be fine to over write with most tuining tools.  If the ECU is locked out by a trial remap APR or  Revo then a good tuner who can remove the chip from the ecu can get the ecu back to factory stock code within 30mins.
 01455 617233
Offline jonnyturbo
Re: 1.8t 150 remap
« Reply #16 on: 23 September 2011, 23:02 »
Yep can vouch for this as i had the earlier revo remap trial before I joined forum . Gave R-tech a call and Nick replaced my ecu as couldn't write over the revo map. Then as Nick says he just removed the chip from my ecu and returned it to stock .
Offline RTechUK
Re: 1.8t 150 remap
« Reply #17 on: 23 September 2011, 23:08 »
Remember that very well all them years back....lol  Then the N249 fault causing the boost drop..... Then Ben fixing you boost leaks under your car and getting crap in his eye and me with a straw sucking on his eye ball on the way home from Ant or Dec land.
Your ecu would not write full stop with the revo code in place, some start to write and fail at around 4%, the some write 100% without issues.
 01455 617233
Offline jonnyturbo
Re: 1.8t 150 remap
« Reply #18 on: 23 September 2011, 23:15 »
Lmao ant and Dec land lol .
The whole straw in the eye story lmao
Offline nottyash
Re: 1.8t 150 remap
« Reply #19 on: 24 September 2011, 19:04 »
I have a Revo remap, and have no problems whatsoever.
They only do VW and Porsche and mine was done by a local porsche specialist
http://www.specialistcarsltd.co.uk/
The free trial is slightly down on power to the full blown remap as the proper one has 4 adjustable settings once its put on.
I had mine tuned to run on normal unleaded rather than gain a few more BHP and need Super unleaded. Power band is brilliant, such a massive improvement to the standard car.
I can recomend Revo no problems.
2002 51 Golf GTI 1.8T Black
2002 02 Golf GTI 1.8T Blue
2003 53 Ford Mondeo ST 220 Estate Blue
2004 54 Mini Cooper S
