Author Topic: Boost pressures  (Read 3335 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Boost pressures
« Reply #10 on: 22 September 2011, 19:57 »
Mines a K03 not a K03S
I know my torque figures when mapped were good (close to the K03s)
but I was slightly down on BHP
looking at my boost gauge it starts from -8 so I need to know is anything above the -8 in boost or is it from the 0 that I'm on boost?
thanks for the replies so far guys I appreciate it
You got ARZ engine code then?
The boost for a turbo car is called MAP (map manifold absolute pressure) not gauge pressure.
-1  = negitive pressure  = vacuum in the manifold = engine is sucking the air in
 0  =  transition void with the pressue reaching atmospheric pressure around 1000mb
+1 = On boost = The air is being forced into the engine from the turbo
If you took you 1.1bar gauge reading you would get a MAP reading of 2100mb, its this what you will log with vagcom.
The k03 will still happy peak 1.3bar 225+lbft but the boost tails off quicker making less peak bhp.
When your car peaks to 1.1bar does it drop of to lower boost? and what boost are you seeing in 4th around 4500-5000rpm as this is the window for peak power from the boost.
(Again you really need to know whats being asked of the boost from the ecu.)
 01455 617233
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Boost pressures
« Reply #11 on: 22 September 2011, 20:04 »
Anything below 0 is vacuum, anything above 0 is boost.
Offline RTechUK
Re: Boost pressures
« Reply #12 on: 22 September 2011, 21:12 »
 Robs comment the on the dyno when we had the lambda and boost gauges on both the 42" plasma screens, he shouted "It looks good its booting to -20psi."       My reply "carry on cleaning the bog"
 01455 617233
Offline Dalo Harkin
Re: Boost pressures
« Reply #13 on: 23 September 2011, 08:11 »
You got ARZ engine code then? Yes
When your car peaks to 1.1bar does it drop of to lower boost? and what boost are you seeing in 4th around 4500-5000rpm as this is the window for peak power from the boost. Yes it peaks to 1.1 and then drops off to anything between 0.5 and 1 then in 4th at the RPM you say it holds 1bar
See comments above
Offline RTechUK
Re: Boost pressures
« Reply #14 on: 23 September 2011, 09:06 »
See comments above
You really need a logging session of blocks 020 114 115 to make sure your car it doing what it should.  Where are you from? as there is a list somewhere of members with VCDS who are willing to help you do a log, in return for a bigmac and fries
You
 01455 617233
Offline Dalo Harkin
Re: Boost pressures
« Reply #15 on: 23 September 2011, 12:21 »
Lol - I have vagcom but havent read the user manual (infact I havent even unwrapped the cable  :grin:)
I live in Stockport, I have had a PM from a member who is going to help me for some KFC  :smiley:
