Author Topic: MIG Welder??  (Read 3650 times)
Offline pid
Re: MIG Welder??
« Reply #10 on: 15 September 2011, 22:48 »
I got 1 of the docky's in Pompey to show me I bought him oggies for a week in return for lunch welding sessions worth it's weight in gold. I'm sure one of them will show u. ( mayb even do the work????)
I'm in the car club at sultan very handy using a ramp and air tools rather than on ur back scraping ur fingers lol. And I always use my ID when buying parts normally get 10% off some times more!!!
Offline Seanl
Re: MIG Welder??
« Reply #11 on: 16 September 2011, 06:57 »
Happy with that, will pop down early next week. I always use my ID card too. 10% off at GSF & ECP, and 10 or 20% at the dealers depending on who is on the parts desk. :smiley:
Offline DOA
Re: MIG Welder??
« Reply #12 on: 16 September 2011, 07:16 »
The steel is typically anywhere from 0.8mm to 1.5mm on cars. As for getting spare steel, try a scrapyard and see if they have any random panels lying around, you might even find one that includes similar shapes to the ones you want to repair. One thing that hasnt been mentioned is prep work, its sooooooooooo much easier to weld thin stuff if the metal is spotless so its well worth cutting out more than you really need to to make the weld quality better and reduce the likelihood of blowthrough.
Offline Seanl
Re: MIG Welder??
« Reply #13 on: 16 September 2011, 19:31 »
Cheers bud!
Offline danny_p
Re: MIG Welder??
« Reply #14 on: 17 September 2011, 00:25 »
id recomend buying a 2nd hand mig.
a lot of the new small migs are utter sh!te, aluminium wound transformers  :sick:   horrible wire feeds, crap torches and some of the gasless ones are even live torch and AC output  :shocked:
look for something like 165 or 185 A sealy supermig that'll do you well
all the VW's have gone bar 1.
Offline Screech16v
  • MK3 20vt AGU
Re: MIG Welder??
« Reply #15 on: 21 September 2011, 20:55 »
+1 to this^^^^ got my mate a second hand sealy 185 about 10 years ago and he uses it alot,and its just brilliant for car work,yesterday i was welding a caddy with a butters 380 on 1mm wire, that was fun :rolleyes: chase the hole !
Offline danny_p
Re: MIG Welder??
« Reply #16 on: 21 September 2011, 23:05 »
last car i was welded up i started off  useing a mates  clarke en90 with gasless because it was there and on. after about 10 mins i was thinking this would proably be easyer with a big mig . it was and with the 1mm wire
i stick welded a wing vent in once just to prove a point that you chould stick weld car pannels if you really really wanted to. ended up haveing to use the tig inverter to do it so really should have tiged it but thats easy and woun't have prove the point.
for learnign to weld imo  GAS learn to weld with that then the rest comes easy
