Author Topic: oil pickup pipe  (Read 5742 times)
Offline daz veedub
  • Operation 1.8t bolf
Re: oil pickup pipe
« Reply #10 on: 22 September 2011, 19:33 »
suppose some will be worst than others iam replacing mine for peace of mind  :smiley:
Offline Dave_IOW
Re: oil pickup pipe
« Reply #11 on: 22 September 2011, 19:38 »
Indeed, thats what i did, after taking it all apart though, i would have preferred to see a sh!tty one, to make the job worthwhile  :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline andybod
Re: oil pickup pipe
« Reply #12 on: 22 September 2011, 19:54 »
it is a very easy job ,
jack up and axle stand car
drain engine oil
remove dog bone mount bolts to gearbox
remove 3 gearbox bolts into sump
remove turbo drain bolts in rear of sump
remove all sump bolts ( a long 5mm ball head allen key is easiest to remove the 3 0r 4 bolts hidden between the sump and gearbox casing the rest can be removed with a 10mm head socket )
remove sump (may need a bit of a lever to break the sealant)
remove oil pick up pipe and clean or replace (for the cost just replace)
re fit in reverse order
parts required
sump plug and seal
oil filter
oil
sump sealant (use correct sealant available on ebay ,eurocarparts etc)
turbo drain gasket
pick up pipe
o ring for pick up pipe
easy as that ,hope this helps andy
Offline Dave_IOW
Re: oil pickup pipe
« Reply #13 on: 22 September 2011, 20:04 »
Dont over-tighten sump bolts, shear easily :lipsrsealed:
Re: oil pickup pipe
« Reply #14 on: 22 September 2011, 20:17 »
This was mine @ 116k.
