Author Topic: bleeding cooling system  (Read 864 times)
Offline biddy
« on: 12 September 2011, 18:48 »
hi guys what is the best way to bleed system on a 2.0 gti
Offline Screech16v
  • MK3 20vt AGU
Re: bleeding cooling system
« Reply #1 on: 12 September 2011, 19:35 »
top the system up to max,start the car with the cap off,sqeeze the top and bottom hoses to push air out,keep sqeezing the hoses and topping the water up to max,give the motor a few revs,turn your blowers to hot ,when you start getting good heat from the vents check the level ,replace the cap .Temp gauge should stay in the middle and top and bottom hoses should be hot,let it idle ,the radiator fan should start after a while,check the level again ,done  :smiley:
« Last Edit: 12 September 2011, 19:40 by Screech16v »
