Author Topic: Coilovers, i have a list any good? and any suggestions? mk2 16v  (Read 3440 times)
Offline Diamond Hell
  • Opinions я Us
Re: Coilovers, i have a list any good? and any suggestions? mk2 16v
« Reply #10 on: 13 September 2011, 13:20 »
"Personally" I wouldn't bother with coilies if it's you daily, do it bit at a time... It's how I did it...
Springs first then save up for the shocks and all the other parts unless you have to do it all at once....
Mines not a show car (as such) it's my daily and I like my own teeth and can't afford to have a bad back!!!
Do this.
Makes far more sense than nailing on some cheap failovers.
You have budgeted for proper alignment post fitment as well, haven't you?
Otherwise you'll need to budget for new tyres as well.
Offline DOA
« Reply #11 on: 13 September 2011, 18:07 »
i got a set of fk ak street and for £209 delivered they're a bargain, they have a fairly hard ride but it's pretty smooth and has improved the handling no end :D
I was VERY surprised when I fitted a set of these to a mates B5 passat as they are actually pretty good in terms of ride quality. However, thats a very heavy bus with a lot more rubber in the suspension than a mk2 so wouldnt like to guess what they are like on a golf. On the plus side, they use progressive wound springs rather than the normal single rate jobs normally fitted to coilovers so there is some potential for ride quality.
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« Reply #12 on: 13 September 2011, 18:33 »
i fitted them a couple of weeks ago and have had the tracking done, and they ride really will, spent twice the amount on my previous car on a shock and spring set and they weren't as good as the coilovers i'm running now, i also got a jom stut brace for about £40 delivered, handles beautifully mate
i have an 8v though, but i can't see them being any different for a 16v  :laugh:
Offline mk2bal
« Reply #13 on: 13 September 2011, 18:45 »
Depends what your idea of a mk2 'looking good' is. I had a 60mm shock + spring kit, and lowering top mounts, but it still wasn't low enough for me.. I've since bought hottuning coilies- very bumpy, and not good handling unless you're on perfectly smooth roads, when you need no shock absorbence,otherwise the car skips about. The stiff springs + low centre of gravity do do it well when on decent tarmac. That's about 400 quid spent now, buying both sets. Old ones 'felt' better, but new ones make car look better imo. I'm now looking to get both decent handling + low enough height, aka a decent set of £450 ish coilies, and going to sort arches right out so the wheels have room to travel, and absorb bumps, even when really low. Thatll be nearly a grand spent to get where I want to be. Not good. I think you should really think about what you want, as its bad to do things twice/three times!! As said, if arch clearance + smooth ride is what you want, get some shocks + springs (koni preferably) but if you want it to look 'how a fat mk2 should' then its got to be coilovers. On the dished ronal ls's I've got it looks pretty sweet, if I do say so myself!!!
