Author Topic: Installing a UK gamma head unit in a Import golf  (Read 2153 times)
Offline mash
« on: 20 April 2005, 22:35 »
Im trying to install a working Gamma head-unit into a Import golf. There is no power when connecting it.  Is there some
power difference between Euro cars and UK cars?
If so,  is there a way round this?
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: Installing a UK gamma head unit in a Import golf
« Reply #1 on: 20 April 2005, 22:42 »
I doubt the power is different between UK and mainland european cars.
Is the headunit a known working unit?
The greatest leveller of them all - the Carousel
Offline mash
« Reply #2 on: 21 April 2005, 11:45 »
Yep it works fine in the UK car.
Offline fireman sam
« Reply #3 on: 21 April 2005, 11:53 »
i know it's probably obvoius but have you checked the fuse panel in the car
Offline mash
« Reply #4 on: 21 April 2005, 15:26 »
Its got a aftermarket Sony head-unit which currently works fine and just wanna swap it out for a Gamma so it looks standard.  If the Sony works then i would have thought the fuses are fine.
Any more suggestions?
Offline fireman sam
« Reply #5 on: 21 April 2005, 17:46 »
i'm sure when i put a sony h u in my golf a while ago i had to swap around the red and yellow live wires to keep the memory. not sure if this will help. are the sony wires connected on the the original vw black plugs. have you tried the fuse on the back of the gamma
