Author Topic: overheating and power steering loss during wet weather  (Read 1662 times)
Offline SoulTaxi
  • 1990 8v-GTI novice :/
« on: 07 September 2011, 10:49 »
Hi chaps, my mk2 8v is overheating during wet weather, also the power steering intermittently cuts out. Are there any suggestions as to what this could be?? all temps and steering are normal when it's dry!  slipping belts maybe?? any help would be greatly appreciated!! cheers!
My other car was a beetle....till it got nicked :(
Offline Mark 2 Mark
Re: overheating and power steering loss during wet weather
« Reply #1 on: 07 September 2011, 11:00 »
Yup the power steering is likely to be caused by a slipping belt, are you getting any squeel too? Might be worth giving it a little tighten. Not a clue about overheating in the wet though!
Offline Agreeable Slick
  • Unit
« Reply #2 on: 07 September 2011, 11:03 »
IIRC the pas and waterpump are on the same belt so if it's slipping that would explain it.
Offline Mark 2 Mark
« Reply #3 on: 07 September 2011, 11:10 »
Ah yeah that's right, would make sense now! How bad would it have to be slipping to cause overheating issues though?!
  • Unit
« Reply #4 on: 07 September 2011, 11:28 »
It wouldn't take much, as if the belt starts to slip when driving then obviously all water will stop moving and just heat up with no where to go.
Offline jmsheahan
« Reply #5 on: 07 September 2011, 16:16 »
This. Had exactly the same problem when I bought my mk2. It overheated badly.
Check the belt!
Offline SoulTaxi
« Reply #6 on: 07 September 2011, 17:27 »
SORTED!!  :smiley:
New power steering belt duly fitted..no probs! Thanks for all your help fellas..cheers!
