Author Topic: maf deep clean  (Read 1926 times)
Offline danmusic24
maf deep clean
« on: 05 September 2011, 13:01 »
anyone got a guide on how to clean MAF pls,or tell me how to go about it..
Offline gasketface
Re: maf deep clean
« Reply #2 on: 05 September 2011, 13:20 »
Forgot to add that all i do is remove air intake pipe from it and sparay loads of the above into the MAF.Let it dry out and away you go.
I had one recently that had hesitation and a bit of a flat spot.I did the above and problem sorted !.
Offline danmusic24
Re: maf deep clean
« Reply #3 on: 05 September 2011, 13:23 »
thats what i trying to solve! cheers for info :smiley:
Offline Seanl
Re: maf deep clean
« Reply #4 on: 05 September 2011, 14:49 »
Personally I would use proper electrical contact cleaner. I dont know the make up of carb cleaner tbh, but I dont think its alcohol based, and if your cleaning an electrical component, you really want it to evaporate properly. I use a cotton bud to clean it as well, and obviously take it very very gentle when your using it.
Offline gasketface
Re: maf deep clean
« Reply #5 on: 05 September 2011, 14:54 »
the one i mentioned above is a methanol/xylene mix if that helps at all.
Offline Seanl
Re: maf deep clean
« Reply #6 on: 05 September 2011, 14:56 »
That should be ok then.  :smiley:
Just leave it for a good while before refitting to ensure its nice and dry.  :cool:
Offline dom
  • Back in a Mk4
Re: maf deep clean
« Reply #7 on: 05 September 2011, 17:21 »
Just be very careful, the MAF is pretty delicate :wink:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: maf deep clean
« Reply #8 on: 05 September 2011, 18:08 »
Exactly what I used when I did one last, any residues left over from non evaporating fluids,could potentially make it function worse.
Re: maf deep clean
« Reply #9 on: 06 September 2011, 00:17 »
Better to replace it tbh.
