Author Topic: Was thinking about this.  (Read 3024 times)
Offline barrym381
Re: Was thinking about this.
« Reply #10 on: 01 September 2011, 22:59 »
an if you do get it change the inlet manifold for a 325i unit as the 323i an 328i need this to free up a few horses :smiley:
Offline bobbarley
  • I'm kind of a big deal...
« Reply #11 on: 01 September 2011, 23:01 »
Get a diesel BMW instead if you want decent economy.
Offline Bellend
« Reply #12 on: 01 September 2011, 23:23 »
35MPG is well optimistic.
With age comes issues, radiators are becoming common on the cars with this age, fairly expensive jobs but I spose you'll do any work yourself so it's just parts.
Where all my moneys went.
Offline Sam
  • Sam I am
« Reply #13 on: 01 September 2011, 23:40 »
What a helmet
« Reply #14 on: 01 September 2011, 23:46 »
25mpg is closer to the mark, rust is or can be a problem, cooling systems are not great, radiators, thermostats and heaters all give trouble plus a pig to bleed afterwards.
Offline Bellend
« Reply #15 on: 01 September 2011, 23:48 »
Yeah the bleed "nipple" or the correct term   :grin: on the rads give out which is a new radiator.
Offline Sam
  • Sam I am
« Reply #16 on: 01 September 2011, 23:50 »
Ok so thats a no go, old derv audi lookout it is then
Offline Mitching
« Reply #17 on: 01 September 2011, 23:57 »
Thought about a passat?
Offline barrym381
« Reply #18 on: 01 September 2011, 23:59 »
wouldnt say tht i have an old e34 535i sport we use for track days now but drove it for nearly 2 years as my transport to work an it never let me down once also had a few e36s an same again
« Last Edit: 02 September 2011, 00:05 by barrym381 »
Offline Guy
« Reply #19 on: 02 September 2011, 00:45 »
I believe that it has the same engine as the E30 325i Sports which are very good, solid and reliable engines. I do think the 35mpg is a bit optimistic though, they simply aren't good on fuel but that aside it could be a cracking motor, very well screwed together and a good work horse !
+1
... but when bmw's start to go wrong, it can get very expensive
indeed.. my dad had his old 530i touring E34 I think.. was quoted 13 hours labour to change a sump gasket... wasn't cost effective to fix it
