Author Topic: strange whiney noise  (Read 1586 times)
Offline Richie_C
« on: 01 September 2011, 14:57 »
Ive just started to get strange whiney noise from what seems to be the rear drivers side wheel. This whiney noise is more apparent when parked up and engine is running at tickover does alter slighty with revs. Its sounds like coming from rear drivers wheel area but also all under the rear of the car i cant pin point it
Any ideas
Thanks
Offline javalin
Re: strange whiney noise
« Reply #1 on: 01 September 2011, 16:18 »
if car isn't moving then its likely to be engine, especially if it varies with RPM.  You need to pin-point it really.  Could be belts, alternator / PAS / A/C etc.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Richie_C
« Reply #2 on: 01 September 2011, 17:59 »
its the fuel pump. just had a look at it under inspection cover unplugged it and the whining stopped. took the fuse out and the whining stopped.
Offline Richie_C
« Reply #3 on: 01 September 2011, 18:30 »
ive just recently changed the fuel filter so unless its sucked some rubbish in i dont think its that. could it be the relay? The wining noise stops when i unplug the pump and also if i take the fuse out. if i turn right the noise quietens a little
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 01 September 2011, 18:35 »
Are you low on fuel?
Offline Richie_C
« Reply #5 on: 01 September 2011, 19:56 »
It was on empty till i filled it up last night then the noise started.
Offline gasketface
« Reply #6 on: 01 September 2011, 20:29 »
"strange whiney noise" ?
I had that for a while.....................then i divorced her  :grin:
Offline Screech16v
  • MK3 20vt AGU
« Reply #7 on: 01 September 2011, 21:40 »
Maybe the pumps just on its way out ,get yourself a spare ready and run that one till you get chance to swap  :smiley:
Offline Richie_C
Re: strange whiney noise from fuel pump
« Reply #8 on: 01 September 2011, 21:42 »
If the relay is on its way out could this cause the the fuel pump to whine? Iam going newquay on monday so need this problem sorting asap
Offline dan_apps
  • too low for british roads!
« Reply #9 on: 01 September 2011, 22:26 »
sounds like fuel pump matey unfortunately
