Author Topic: feeling in rear end  (Read 2246 times)
Offline stainesy
feeling in rear end
« on: 30 August 2011, 19:51 »
just spotted a thread on hear about front suspension wobble and reminded me to ask about something i get sometimes in my car.
every now and then i will take a corner and my rear end has a feeling as if it kinda slips but it dont.
i can make it happen. if i drive strait then quickly steer one way then back my rear end my front end goes one way then the other as it should and the back end does the same but seems like it has to catch up as if the tyres where realy soft if you no what i mean.
hard one to explain this.
im low on coilys so suspension is solid with 45 tyres. could it be tyres movement?
as on most cars the suspension travel would hide it but with it being solid am i feeling the tyres swaying if you no what i mean?
Offline javalin
Re: feeling in rear end
« Reply #1 on: 30 August 2011, 20:05 »
rear bushes?
Have you done a spanner check?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline mellow yellow
  • A Driffield Dubber!
« Reply #2 on: 30 August 2011, 20:10 »
thought this was a totally different thread going by the title  :laugh: ....
sounds like bushes as said above.
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 30 August 2011, 20:38 »
Low tyre pressure
Rear axle bushes
Very loose wheel bearings
I'd check these  :smiley:
Offline stainesy
« Reply #4 on: 30 August 2011, 20:44 »
rear bushes?
how do i do that then?
they easy to change?
« Last Edit: 30 August 2011, 20:46 by stainesy »
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 30 August 2011, 20:57 »
rear bushes?
Did mine about a month ago had to make a tool to wind them in ,quite labourious and about a 3 hour job start to finish
Offline tshirt2k
  • Been there...Done that...
« Reply #6 on: 30 August 2011, 21:06 »
Or change for poly. Much easier
Mk3 ABF 16VT Megasquirt V3
Offline stainesy
« Reply #7 on: 30 August 2011, 21:21 »
How do I do it and what do I need?
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 30 August 2011, 21:31 »
http://forums.vwvortex.com/showthread.php?3242686
You dont need to take the beam off and you can do it on your own but this shows whats involved  :smiley:
