Author Topic: aaaggghhh HELP oil  (Read 3550 times)
Offline stainesy
Re: aaaggghhh HELP oil
« Reply #10 on: 29 August 2011, 18:37 »
Just had look at puddle. Its browny colour and there's about a litre of it. Power steering level fine. And engine oil level at max. Not had chance to check gearbox oil yet.
Starting become obvious now. I recon its gearbox oil.
Fcuk sake my car has 3 hour left on ebay auction aswell.
Sod fcuking law.
well atleast i get to keep her now.
if it is gearbox oil what seals are there that could have gone?
also is it cheaper to get seal fixed or replace gearbox?
« Last Edit: 29 August 2011, 18:45 by stainesy »
Offline stainesy
« Reply #11 on: 29 August 2011, 19:07 »
sh!t if gearbox has oil leak im going to have to break her  :sick:
cant aford to fix that  :cry:
« Reply #12 on: 29 August 2011, 19:14 »
Sounds like gear oil, might be a seal gone.
Gavv8
« Reply #13 on: 29 August 2011, 19:24 »
Check the gearbox level and top up then give the area around the box a good clean (pressure wash but not the engine) then drive it around and see what happens, i don't know if there is a seal on the mainshaft but thats usually where most boxes fail then leak in to the bellhousing.
Offline stainesy
« Reply #14 on: 29 August 2011, 19:38 »
ok so if that is the case how much am i talking here to get fixed?
would it be cheaper to get another box or to have it fixed?
what everit is i looks like it dropped a litre or more oil over night
fcukit im starting to add up how much i can sell all my mods for already  :sick:
« Last Edit: 29 August 2011, 19:42 by stainesy »
Gavv8
« Reply #15 on: 29 August 2011, 19:48 »
If its just the mainshaft seal its a cheap part but a box out job, but if the mainshaft seal is leaking badly enough to drop a litre it could also ruin the clutch so better get on top of it sooner rather than later.
« Last Edit: 29 August 2011, 19:50 by Gavv8 »
Offline stainesy
« Reply #16 on: 29 August 2011, 19:57 »
well the car is now not going to be used till i check oil leven and see where its leaking from then will stay in garage till i can aford to fix it.
if its a box out job then makes sence to put new clutch in and release baearing as mine always clicks.
so what we talking here? £400? or more?
VW BUSH
« Reply #17 on: 29 August 2011, 20:05 »
Clutch £75
Bearing and Seal kit £15
Clutch cable (optional) £20
Oil £10
+Labour if you cant do it your self :smiley:
Offline stainesy
« Reply #18 on: 29 August 2011, 20:16 »
Clutch £75
Oil £10
i wouldnt no where to start
Gavv8
« Reply #19 on: 29 August 2011, 20:18 »
It's not a bad job, like anything just make sure you have all the parts you need, a manual and the right tools and give yourself plenty of time to do it, most decent mechanics can drop a g/box out in under an hour.
