Author Topic: Mk3 front strut top nut problem  (Read 6193 times)
Offline dansmk3
  • FULL TIME JUNGLIST
Re: Mk3 front strut top nut problem
« Reply #10 on: 29 August 2011, 15:21 »
im having exactly the same dramas at the mo.
mine dont look as bad as yours but my drill is on charge right now so i can butcher the bastids off lol
Offline gasketface
« Reply #11 on: 29 August 2011, 16:40 »
I do'nt think mk2 top plates are the same.They do'nt come with new top mounts either.
Another tip  :laugh:.
Drill through the side of the nut and break it away from the shaft.It's easier than drilling the shaft.
Offline mark-mk3gti
« Reply #12 on: 29 August 2011, 17:45 »
Sounds like a good idea! Got my drill on charge, got some drills, but no chisel, but got hammers and big screw drivers! :) May have a go at that! If weather is good tommorrow I'll be up at 8, leave me time to get it done cos it's my daily!
Offline dodge_vdub
« Reply #13 on: 29 August 2011, 19:25 »
i had the same problem, the struts we're being binned so a set of stilsons round the shaft and and a mate on a spanner  on the top nut soon had them off  :smiley:
"Lets break out the shotguns, we're going too town!!"
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 29 August 2011, 19:42 »
Easy peasy this is the way^^^^^^^
Offline AudiA8Quattro
« Reply #15 on: 29 August 2011, 21:56 »
+1 This is exactly what i would do.
Put the drill away, and try this method first.
Offline mark-mk3gti
« Reply #16 on: 29 August 2011, 22:02 »
Not sure, had a look at nut and not much to drill at, so thinking of going to a tyre place in morning and getting em to have a crack at it,  soaked in wd40 now for what it is worth, would being driving 5mins with nuts loose, but just have to take it easy,
That and I don't have any stilsons,
Would love to sort em tommorrow, so will keep updated! :)  my dad has air ratchet but he is working, so may have to wait a few days till I'm off again when he is..
« Reply #17 on: 29 August 2011, 22:04 »
Do not drive it with the nuts loose, when you steer the car they could come off!!
Offline Screech16v
  • MK3 20vt AGU
« Reply #18 on: 29 August 2011, 22:27 »
You can do it with mole grips also if you got any
« Reply #19 on: 29 August 2011, 22:29 »
+1 mole grip will also work, just a bit more messy  :grin:
