Author Topic: DanChave's MK3 Volf - Sold ;)  (Read 150184 times)
Offline Seanl
Re: DanChave's MK3 Volf - Wheels are painted :)!!!
« Reply #380 on: 16 February 2012, 18:50 »
Much better mate!  :cool:
Offline DanChave
« Reply #381 on: 16 February 2012, 18:53 »
Cheers Sean! After working on her and looking back on all the work I have done so far, I'm having doubts on weather I should sell her now!
Offline VR6_Wherry
« Reply #382 on: 17 February 2012, 09:45 »
If you sell, it must be replaced by either a VR6 or a Mk1! If you don't sell it, then we want to see a 1.8T engine in there!! :cool:
Offline stow1985
  • 'when im cleaning winders'
« Reply #383 on: 18 February 2012, 21:29 »
Looking good!
Offline DanChave
« Reply #384 on: 26 February 2012, 09:49 »
Recently the mk3 has developed a problem with starting first thing in the morning. The starter motor will turn and turn and turn, but it wont catch! When it eventually does, its a bit lumpy, smooths itself out and then it feels fine. Until you go from first to second gear and there is a loss of power. Eventually, when the engine warms up, its fine and drives completely norma and I wont get any more starting issues for the rest of the dayl! I also noticed this morning, it was low on water, which it never has been before.
Since this problem started, I have replaced the spark plugs, the dizzy cap and rotor arm, and the air filter and also the rocker cover gasket (which was leaking) and also replace the throttle body to inlet gasket, as that was pretty much in two pieces lol! The HT leads looked pretty new, so I didn't replace these. Could it be as simple as replacing the leads? I don't want to buy more parts, unless I know it's going to fix the problem.
Any help would be greatly appreciated!
Offline murraymint
« Reply #385 on: 26 February 2012, 10:26 »
Can't help you with the starting problem, although my 1.6 did this a couple times but then stopped so I didn't look into it. Anyways when are we gunna see this new project you've bort?
josh
Offline DanChave
« Reply #386 on: 26 February 2012, 11:09 »
Unfortunately, due to the extent of rot I found on closer inspection, the GTI project had gone to the scrapyard lol! It's a good job I hadn't handed over the money lol!
Offline murraymint
« Reply #387 on: 26 February 2012, 13:33 »
O right. Well good luck with finding another one  :smiley:
josh
Offline DanChave
« Reply #388 on: 26 February 2012, 15:44 »
I am just gonna keep the 5 door now mate, better the devil you know and all that! :)
Offline murraymint
« Reply #389 on: 26 February 2012, 15:46 »
Sounds like a plan, I, thinking I shoulda kept the 1.6 due to 40mile round trip to work everyday, but loving the abf in the gti  :cool:. You gunna do an engine convo on the 5 door?
josh
