Author Topic: mk1 cab fuel filler neck  (Read 4988 times)
Offline ned
Re: mk1 cab fuel filler neck
« Reply #10 on: 21 April 2005, 12:48 »
Nice one Phil, thanks for that.  :smiley: At least I've got a few avenues to try, if I get any success I'll be sure to let you all know.  :smiley:
Update:
GSF Want £96 + VAT and it's not a stainless steel one but OE apparently
VW Stealers want either £136 or £115 + VAT depending on if its got some green bit at the top or something for unleaded :shocked:
Gibby, mine is on its way out, two heads are better than one and also increases buying power reducing costs if we get then done at the same place, let me know how you get on.
MK1 Rivage With 195's not 185's !
Offline dj g
  • vw gals
« Reply #11 on: 23 April 2005, 23:05 »
i had one from sanburns coventry was told this would fit it is stainless steel i think but was a little long but now my my fuel cap sticks out what went wrong :sad:
Offline Flidster_uk
« Reply #12 on: 24 April 2005, 20:11 »
you can buy a cheap mk2 filler neck around £27 its a heavier gauge material, you have to cut the mid section and apply two rubber sleeves to the neck instead of the one connecting to the tank, the rest bolts lines up to the fixings.
1990 CAB GTI Saphire Met. / 1994 Ice grey violet VR6 Corrado
account.<br />http://www.golfgtiforum.co.uk/gallery/albums/userpics/18662/cab.jpg
Offline bryant
« Reply #13 on: 16 September 2005, 17:43 »
I've been reading a thread on the GSF website and someone was saying that the Golf mk1 filler neck was the same as a Scirocco mk2, only a bit longer. Is this correct? cos I wanna replace mine soon.
Offline gibby
« Reply #14 on: 17 September 2005, 00:12 »
Not sure to be honest but I know for definite that the mk1 tintop is different to the mk1 cab but the mk1 tintop can be made to fit the mk1 cab. The mk1 tintop is also a hell of a lot cheaper.
......now officially dubless.
Offline bryant
« Reply #15 on: 17 September 2005, 20:50 »
Yeah, I think the tin top is the same one as the Scirocco's only longer as a rocco is lowerslung so the fuel pipe runs to the tank above the rear wheel = corrosion. I think new Mk1 filler necks are about £30 from GSF, so I'll ask them.
Offline dj g
  • vw gals
« Reply #16 on: 18 September 2005, 21:42 »
how would you fit the tin top type to the cab cause i think that is what is on mine and it sticks out at the cap needs adjusting but how :huh:
Offline gibby
« Reply #17 on: 19 September 2005, 09:42 »
Not 100% sure, but I think that when it's first put in it should have been cut slightly in order for it to be fit properly.  :undecided:
Offline dino
« Reply #18 on: 27 September 2005, 13:55 »
I HAD MINE FROM GSF AND WE HAD TO BEND IT SLIGHTLY AT THE TANK END TO GET IT TO FIT BUT AFTER THAT IT WAS BANG-ON, I HAVE A 91 CLIPPER CAB, IF THE FILLER NECK IS RUSTED MAKE SURE YOU FISH OUT ALL THE BITS FROM THE TANK WITH A MAGNET.
