Author Topic: front struts from a 1.4, to fit a TDI 130?  (Read 802 times)
Offline leemansiuk
« on: 23 August 2011, 19:25 »
Hi,
I am looking to replace the front shocks and springs on my Mk4 TDI 130. I know a guy who has some from his old MK4 1.4 petrol - but can anyone please tell me if these will be the same fit?
I just thought the TDI might be heavier so may use an uprated set of shoocks and springs but I am unsure?
I cant look at lowering ones as I'll bottom out on my drive way - so I need to get original OEM hight struts / shocks
any advice would be a great help  :undecided:
Offline Rhyso
Re: front struts from a 1.4, to fit a TDI 130?
« Reply #1 on: 23 August 2011, 19:28 »
Will fit but won't work as you correctly surmised that the TDI engine is much heavier
Welcome to the forum by the way  :smiley:
Try Euro Car Parts; as forum members we get 25% discount  :wink:
Offline leemansiuk
« Reply #2 on: 23 August 2011, 20:53 »
Thanks for that  :smiley:
I will take a look there
Would you say its wise to change springs at the same time or would just the shocks be ok?
are gas better than oil for shocks?
Offline Rhyso
« Reply #3 on: 23 August 2011, 21:03 »
If you're knocking on 100K I'd replace the lot.  I had a spring snap on my Golf at approx 83K; when the others were removed it looked like the other one was about to do the same!!
Don't forget to change the topmounts too; much easier to replace everything in one go as it will save you money in the long run  :smiley:
