Author Topic: Battery cable  (Read 832 times)
Offline chrisbeg34
Battery cable
« on: 23 August 2011, 12:29 »
Sorry if this has been asked before, have searched but can not find it.
Had to take battery off last night to charge it as it went flat, put it back on this morning, but no idea where this cable has come from.
Can only see this that it might attach to
If this cable does go here, what does it actually do??
Thanks for help in advance
Offline dragongreengolfgti
  • my golf gti mk3
Re: Battery cable
« Reply #1 on: 23 August 2011, 12:31 »
looking at it i would say its for your alarm system and if correct it will go on the connector underneath next to the red one assuming the cable is black on the opposite side?
Offline chrisbeg34
Re: Battery cable
« Reply #2 on: 23 August 2011, 12:36 »
The cable on the first picture is pure black and goes straight to the neg terminal, I will need to check the colour on the otherside of the block connector on the 2nd pic. This may never have been connector only had the car about a month, and did not even know it had a alarm :undecided:
There is n fob, should it bleep or something when you look the door. Sorry really new to golf's
  • my golf gti mk3
Re: Battery cable
« Reply #3 on: 23 August 2011, 12:40 »
ah rite if you dont have a fob then i'd leave it well alone and forget about it as it may mess with the immobiliser its definately an add on though see if you can trace the wires back to anything  :smiley:
Offline chrisbeg34
Re: Battery cable
« Reply #4 on: 23 August 2011, 12:42 »
Thank you so much for your help, will have a look into the wires, and see where it leads
